Problemas con la actualizacion del firmware de image press c1
  • DANIELCANON
    • Jun 2011
    • 187
  • teckat
    • 16083
    Re: Problemas con la actualizacion del firmware de image press c1
    Hello friends I need help I'm just guiding the manual to update the firmware of the C1 ip thing is that I override the individual modules as SYSTEM, LANGUAGE AND RUI. I did this and updated in order to get the Spanish language on the screen of the copier. Well these modules were updated but what happens now is that does not activate the normal paper size manual feed is thick grueso1 assets other than 2,. <br> Guess we must also update the module MEDIA. <Br > I can also a doubt over the DCON upgrade to version 21.01 as I do this to update this module has to update the BOOT together or independent. Can you update the BOOT, or to update you must change the DIMM ROOM? <br> Can I upgrade only the DCON? Why update the RCON is proved necessary to update the DCON? <br> <br> One more question on the screen of the copier there is a window to put the advertising company that is buying the team, I think the MEAP or not I need the help of you. or not it can send a document that details the correct way to do this. Acontinuacion the show as been updated: <br> <br> LIMA - PERU. <br> BEFORE <br> <br> DCON <br> RCON 07.01 11.03 00.03 <br> <br> ECO PANEL FEEDER <br> 05.01 41.52 05.00 <br> MNCONT <br> NIB ; 24.04 <br> LANG EN, FR, DE, IT, JP 24.04 01.07 <br> <br> BOOT ROM OCR 16.01_C <br> JA TTS-TTS-IN 03.06 03.06 <br> WEB-BRWS <br> HELP <br> 01.01 20.02 20.01 <br> <br> <br> DAV WEB AND IMAGINE IF THIS LIST AS QUEDO UPDATE SYSTEM, LANGUAGE, RUI
    READ THIS PDF>>>--imagePress C1_DCON v21.01_TP09.pdf
    do a select ALL on the STT the boot rom will be automatically updated/if prompted do a overwrite of firmware
    • DANIELCANON
      • Jun 2011
      • 187
      Originally posted by teckat
      READ THIS PDF>>>--[ATTACH]11717[/ATTACH]
      muchas gracias
      • ramcess01
        • Jun 2013
        • 18
        hii need this firmware please
