iR 4570
  • hory_143
    • 23
    iR 4570
    i have a problem with the hdd, i replaced t5he hdd from iR 6570 in the 4570 and by reinstaling the systemsoftware by sst get error
    Module : SendFile () -5 can anyone help me please...
    Thnks
    My e-mail
    hory_143@yahoo.de
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: iR 4570
    Need to format the HDD using SST.
    • hory_143
      • 23
      Re: iR 4570
      i tried to formatthe hdd with sst, but not going the error is alredy known....
      • teckat
        • 16083
        Re: iR 4570
        Thnks
        My e-mail
        hory_143@yahoo.de
        Format the HDD in the 6570 first/ then put it in 4570> & do the 4570 format again
        don't understand that SST message/ Module ????
        uninstall SST 4570 firmware & re register it in SST
        u can not Format a 6570 HDD with SST that u put in a 4570
        both of the models HDFormat.ift files are encrypted and different
        the 4570 HDFormat.ift file will not see this 6570 HDD unless it is the same model u pulled out of the 4570
        both use the same OEM/ but someone may have changed the 6570 before
        OEM part# WM2-5216-000
        (Hitachi) HTS541020G9AT00
        • hory_143
          • 23
          Re: iR 4570
          Thanks!
