Does Canon IR3300 has a tech mode? What are the tech mode.
  • Gesttech
    • Oct 2009
    • 123
    [Misc] Does Canon IR3300 has a tech mode? What are the tech mode.
    Hi
    I would like to know the tech mode of canon IR3300. Im a tech of ricoh its not same. i help a client that have both ricoh & canon copier. Does the replacement of drum need to reinitialize the TD sensor.
    Thanks.........
    Re: Does Canon IR3300 has a tech mode? What are the tech mode.
    To enter service mode press
    * 2+8 *
    Hit 2 +8 at the same time
    As you have replaced the drum you should do the following
    COPIER>FUNCTION>DPC>D-GAMMA press ok
    Exit service mode by hitting the yellow reset key a few times.
