Throubleshuting: C2620 Calibration Utility Driver
  • Smartmind
    • Aug 2011
    • 61
    [Misc] Throubleshuting: C2620 Calibration Utility Driver
    Hello! Well, i'm trying to Calibrate a Canon C2620 With a scanner CanoScan LIDE100, so my question is: Do somebody knows any Canon C2620 Calibration utility Driver that suppor a CanoScan LIDE100? Thanks for any help.
  • teckat
    • 16083
    Re: Throubleshuting: C2620 Calibration Utility Driver
    U can't calibrate the 2620 printer that has it's own scanner/copier glass-
    if u have a 2620 printer only model that does not have the copier glass-
    you will need to use the Color Calibration Utility CC-100 on a Windows PC>can be found here below on link...
    http://usa.canon.com/cusa/support/of...ersAndSoftware
    it supports the Color imageRUNNER series Base Printer model only. If you are using the Color imageRUNNER series Copier model, please use the printer's color calibration (Automatic Gradation Adjustment) function. The utility is not supported if the copier is connected to an imagePASS.
    Compatible Scanners
    - CanoScan LiDE60
    - CanoScan LiDE70
    Canon U.S.A. : Consumer & Home Office : CanoScan LiDE100
    • Smartmind
      • Aug 2011
      • 61
      Thanks a lot Tekat! do you know where do i can find the compatible Utility to calibrate my C2620?
      • Smartmind
        • Aug 2011
        • 61
        Canon U.S.A. : Support & Drivers : Color imageRUNNER C2620/C3220
        Compatible Scanners
        - CanoScan LiDE60
        - CanoScan LiDE70
        Thanks a lot Teckat! I did found the utility, but when i run it, it said that doesn't find any Scanner i can't make a new calibration, i already install the scanner driver and printer driver, Any Idea?
        • teckat
          • 16083
          your CanoScan model might not be compatible to the Calibration Utility CC-100 /
          U may need to call Canon to see if the 2620 supports a CanoScan LIDE100 ??
          READ THE guide below/ u may need to uninstall/re-install
          Remember >
          if u have a imagePass Firey connected and or a Printer that has Copy Glass this Calibration utility will not support either set up-
          I will do some research_
          If u have the stand alone Printer> use below
          Canon Color Calibration Utility CC-100 v2.6 for Color imageRUNNER C2620/C3200/C3220/4080/4580/5180. This version adds support for Windows Vista.
          here is a CC-100 Guide>Color Calibration Utility CC-100 Guide.pdf
          • Smartmind
            • Aug 2011
            • 61
            Remember >
            here is a CC-100 Guide>[ATTACH]11765[/ATTACH]
            OK My C2620, it was a Printer with the imagepass Firey, but The imagepass hard drive is dead, so i took it off, so now the printer it is printing without imagepass unit, but the print out photo colors are not accurate, so i'm trying to do a color calibration, but i can not make it work. please help, am i doing something wrong?
            • teckat
              • 16083
              DOES YOUR 2620 PRINTER HAVE GLASS ON TOP/ it is known as a READER/SCANNER ??
              if it does the calibration utility will not work-
              if not call 1-800 OKCANON , to ask if the 2620 will support your stand alone scanner
              post a picture of your printer
              also when u removed the Fiery - did u
              1. Enter Service mode (Additional Functions > 2 and 8 > Additional Functions).
              2. Select Copier > Option > Int-Face > IMG-CONT.
              3. Change the setting of IMG-CONT to "0"
              • teckat
                • 16083
                CC-100 UTILITY/ to use this calibration utility u need to meet all of the following>
                1. CanoScan connected to PC or Mac
                2. Stand alone Printer>* Note - The printer only model that does not have the copier glass.
                3. No Fiery (imagePass)attached to Printer.
                4.
                Install of Calibration Utility CC-100
                5.*LiDE 100 Scanner Driver Ver. 14.0.3 (Windows ...
                File Name: lide100win1403ej.exe/or the Mac driver if needed-
                *This product is a TWAIN-compliant scanner driver for Canon color image scanner.
                Canon Color imageRUNNER C2620.
                About connecting a CanoScan LiDE100 to the machine.
                Our CanoScan scanners are designed for connection to a computer; it would not be able to be connected directly to a Canon imageRUNNER machine.
                Dave
                Product Support Representative
                Special Note:
                the direct assistance of a Canon telephone support representative may be
                required. Please call 1-800-828-4040, 8:00 a.m. - 12:00 midnight ET
                Did u read the GUIDE I posted ???????
                for CanoScan LiDE 100 / U need to go in the Advanced mode on the CanoScan menu to calibrate it-
                when u scan an image into the PC to print out on an imageRunner that is a stand alone Printer without a Reader> u should be able to First calibrate the 2620 with the CC-100 UTILITY.
                otherwise the best bet would be to call for a trained Canon tech to inspect your set-up-
                • Smartmind
                  • Aug 2011
                  • 61
                  4.
                  Dave
                  Special Note:
                  Thanks for your time and help, I just have one more question, Is there any way to calibrate My C2620 with the reader on it, but no fiery?
                  • Smartmind
                    • Aug 2011
                    • 61
                    By the way, if the CC 100 utility is compatible with the C2620, it work just in case that the printer have not Imagepass Fiery or Reader?
                    • teckat
                      • 16083
                      Yes > why didn't u tell me u had a Reader
                      NOTE:
                      There many things that effect your COLOR Output in this model (LASER/DRUMS/ITB BELT/TONER/TRANSFER/SEPARATION/FUSER/PRINTER ENVIRONMENT/
                      if you are not a trained tech/ u need someone to inspect this printer/ Calibration has it's limits on a poorly maintained Printer
                      Under Additional Functions key on control panel
                      Set up Cassette 1 with intended Paper Type> Plain or Heavy> put in choice of your paper>
                      select>Adjustment / Cleaning and select Auto Gradation Adjustment
                      be sure to select FULL ADJUST
                      see instructions below / just follow the prompts/
                      click on pics for better view
                      Note: If the customer is planning to print/copy a job on Heavy Stock (Over 105g/m2 or ~55lb) it is
                      recommended to select Heavy 1/2 .
                      When running a Plain Paper job (Below 105g/m2 or 55lbs) select Plain.
                      u can also calibrate for heavy paper( photo paper ) see same instructions
                      click on & download the free guide>>>Color IR Quick Ref Guide 2009.pdf
