IPF w 8400
  • bat
    • Sep 2008
    • 140
    IPF w 8400
    Hi all...
    A few days ago printer displayed message "Printhead Error". I have prepared new printhead but, message is stuck on display, I even cant get into Main Menu printer is not responding to commands...What can I doo?
  • JustManuals
    • Jan 2006
    • 9838
    Re: IPF w 8400
    Call a Canon certified tech.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: IPF w 8400
      Do you replace print head?
        • 16083
        Re: IPF w 8400
        Originally posted by bat
        Hi all...
        Printhead comes with updated firmware. BE SURE to install the firmware BEFORE replacing the printhead. Instructions are included.
        READ THIS PDF>>>Print Head BC-1300 and BC-1350_TP09 023[2].pdf
        Before replacing the print head,
        please be sure to perform the firmware upgrade with the old print head installed.
        Publication is to inform you of a change to the print head for the BC-1300 and BC-1350 print heads.
        your's is the BC-1350
        • bat
          • Sep 2008
          • 140
          Re: IPF w 8400
          Thanks all, I have solved the problem. The machine just needed reset. The printhead is still working but probably will need to be replaced soon.
          • V-P
            • Apr 2011
            • 679
            Re: IPF w 8400
            Reset ??? How do you do RESET ?
              • 16083
              Re: IPF w 8400
              what reset ??
              u pulled the plug ?
              • bat
                • Sep 2008
                • 140
                Re: IPF w 8400
                Originally posted by teckat
                what reset ??
                u pulled the plug ?
                I ment reset, or clear error condition mr.field supervisor. Obviously some people here do not want to help but flaunt their titles.
                Thanks to those who really wanted to help.
                6.1.5 Troubleshooting When Service Call Errors Occur
                6.1.5.1 Outline
                0009-7121
                When a service call error occurs, the error is not cleared and the error display remains on the operation panel even if printer power goes off and on.
                This is to avoid thet the user can cleare service call errors preventing the printer from damage.
                Service call errors can be cleared, however, by starting up the printer with the service mode.
                • zoraldinho
                  • Mar 2008
                  • 5015
                  Re: IPF w 8400
                  That hurt!
                  • V-P
                    • Apr 2011
                    • 679
                    Re: IPF w 8400
                    6.1.5.1 Outline
                    0009-7121
                    Let me get this straight:
                    First you cry for help, (and you get it for free), than you play professional (with the reset thing)
                    And when we ask you what do you mean by reset - you get angry & start questioning the skills ????
                    Now to the RESET option:
                    In copiers - the term "Reset" means smth mainly to the fixing error codes (E001).
                    When you have such an error code - you are able to "reset" it in service mode.
                    In plotters - the term "Reset" doesn't mean much.
                    This is why you had such a reaction from me and Teckat.
                    But to each its own...
                      • 16083
                      Re: IPF w 8400
                      6.1.5.1 Outline
                      0009-7121
                      I am not here to flaunt a title/ I could care less about my title-
                      I am here to help, -
                      RESET & CLEAR are two completely different terms used on Canon products/
                      I will never tell/or explain to an end user (customer) how to Clear an ERROR over the phone. With out being onsite to inspect the issue.
                      RESET / depending on the customers explanation of the problem over the phone or e-mail, I will determine if this is a simple issue (counters,server issues,jams,paper trays,drivers,waste bottle,etc.)
                      • rrrohan
                        • Sep 2011
                        • 1977
                        Re: IPF w 8400
                        when i did it about a year back i had to go into service mode and reset it and to get it to start a massive purge
