ir 3025
  • TEC DOG
    • Sep 2011
    • 113
    ir 3025
    When i turn on copier on display:Remaining data that is not needed is being erased.Do not turn of the main power.
    Format HD
    Installed new firmware
    Clear m-con
    Inspect ram
    Any help.Thanks
  • charm5496
    • 2387
    Re: ir 3025
    your machine has the HDD erase installed in it
    • TEC DOG
      • Sep 2011
      • 113
      Re: ir 3025
      HHD erase in my machine?Can you explain please??
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Re: ir 3025
        I believe he is referring to the Hard Drive Erase security kit option that can be installed on copiers.
        • charm5496
          • 2387
          Re: ir 3025
          whenever you turn the power off/on on the copier the machine is going to go through that process where it erases all user data on the HDD to keep there information secure.
          • TEC DOG
            • Sep 2011
            • 113
            Re: ir 3025
            But machine is just fine after 20 sec!!
            • TEC DOG
              • Sep 2011
              • 113
              Re: ir 3025
              How to delite this option please?
              • charm5496
                • 2387
                Re: ir 3025
                that option cannot be removed if I remember correctly. I think the only way to get rid of it is to install a new HDD and reload the entire system on the device. You will to physically remove the HDD erase kit from the device along with the current HDD.
                The time it takes is dependent on the amount of data that has been stored since the last time the machine was power cycled.
                • TEC DOG
                  • Sep 2011
                  • 113
                  Re: ir 3025
                  Thans a lot.
                  • charm5496
                    • 2387
                    Re: ir 3025
                    not a problem.
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      Re: ir 3025
                      The hard drive erase feature probably cost in the neighborhood of 400/500 dollars, it would be a shame to undo it and lose that value. As to the removal of the kit, I can find no installation manual for the feature, which would let you know what you would have to remove. The hard drive that is currently in the machine should be able to be reused in the copier after the kit is uninstalled, you would simply have to reformat the drive and reload system software...
                      • Simons
                        • Jun 2008
                        • 490
                        Re: ir 3025
                        I just experienced this. I went into level 2 and license transfer area. Find the HDD erase option and change 1 to a 0 . My machine didnt have the encryption kit so that is all you have to worry about. I got a transfer key and now the option is off. I then updated systems s.
                        On the 3245 this can be tricky if option was put in before version 35. was installed. there is a KB article about this kit and that model in regards to removing it or transfer.
                        • teckat
                          • 16083
                          Re: ir 3025
                          HDD Data Erase Kit-B2
                          If the HDD Erase Kit is installed on the machine with a system software version lower than 35.06, this "License is Invalid" message will appear. It occurs when the license key is input before upgrading system software. This problem will not occur on a machine with system software at 35.06 or later.
                          An important note here is the order in which the license number and the software is installed, when the System Software is lower than 35.06. If the license key is input before the system software is updated, the message will occur. If the system software is updated to 80.02 before the license number is installed, it will not. If the machine is at 35.06 or higher, it will not cause a problem.
                          Note:
                          If this issue occurs, it will be necessary to contact the Technical Support Center for further troubleshooting / investigation.
                          • Mina Banoub
                            • May 2011
                            • 50
                            Re: ir 3025
                            Dear Tec Dog,
                            you can delete this option using the following steps
                            go to service mode level 2>copier >option>LCNS-TR > TR-HDCLR this will generate a transfer code that you can use to transfer this option to another m/c and will stop this function on your m/c.
