IR4570 vs IR3045
  • madu132
    • Dec 2008
    • 65
    IR4570 vs IR3045
    Hello guys,
    I want to know what is different between ir4570 and ir3045. which one is "better".
    I saw on the brochure the speed is same, but I cant find the different between them.
    are they built in same design/machine?
    which model is newer?
    thank you in advance
  • Brian8506
    • 1665
    Re: IR4570 vs IR3045
    3045 is next generation. I find them the same. 3245 came out after 3045
    • gensys
      • Jan 2011
      • 323
      Unequivocally choose the iR 4570
      The Road will be Mastered by >>> the Going...
      • nasertop
        • Aug 2011
        • 40
        Hai, i think ir3045 is better than ir4570. Because there are some modifications. I note that the right side top door is possible to open more wide. It is useful to remove the fixing very smoothly. There is one tension plate at the first cassette pick up assly.so that the papper jam at vertical path al most reduced. Pick up assly vertical sensor flags has metal covers. So that the in-correct papper size problem not happend.
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          speed and capabilities of both machines are the same. The 3045 series is basically the 4570 machine with all the modifications to the 4570 factory installed. The right door feed system was upgraded by many modifications, beyond that, they are basically the same machine. They use different system software and key electrical components, main controller etc, etc,...
          • madu132
            • Dec 2008
            • 65
            thank you for the explanations guys.
