Fa Canon L220 Fax ~ Start Button!
  • Smiley27
    • Apr 2011
    • 160
    I want to replace Start button since its broken,would appriciate if some1 would tell me ,or give me part of service manual where its described how to replace it ... Also,I am replaceing it(button) with Fax Canon B100 , so would also need b100 service manuals
    Thanks for your help in advance
  • JustManuals
    • Jan 2006
    • 9838
    Re: Fa Canon L220 Fax ~ Start Button!
    I've got this Parts & Service manual, email me if interested.
    Paul@justmanuals.com
    • songela
      • Mar 2008
      • 216
      That button is not among service parts-you'll not find its replacement procedure in the manuals. The logic will work fine-if you have been in the field for long enough, or else find a qualified tech.
      • teckat
        • 16083
        Originally posted by smiley27
        i want to replace start button since its broken,would appriciate if some1 would tell me ,or give me part of service manual where its described how to replace it ... Also,i am replaceing it(button) with fax canon b100 , so would also need b100 service manuals
        thanks for your help in advance
        5 --- hc1-2018-000 1 key top, function
        [ATTACH=CONFIG]11843[/ATTACH]
        • Smiley27
          • Apr 2011
          • 160
          Youre KING, thank you !
          • Smiley27
            • Apr 2011
            • 160
            I need one more thing,what is part number for part numbered as ten on picture?Can some1 look for it at parts manual,I need to order that plate with ''tits'' cos 1 of tits is broken ... would appriciate fast reply
            • teckat
              • 16083
              HM1-0870-000 1 OPCNT BOARD ASS'Y
              OPERATION PANEL ASS'Y (FAX-L220/L295)
              1= HC1-2017-000 1 HOLDER, SENSOR
              2= HC1-2016-000 1 COVER, OPERATION PANEL
              3= HC1-2020-000 1 KEY TOP, DIAL
              4= HC1-2019-000 1 KEY TOP, ONE TOUCH DIAL
              5= HC1-2018-000 1 KEY TOP, FUNCTION
              6= HC1-2015-000 1 COVER, LCD FAX-L220
              6= HC1-2027-000 1 COVER, LCD FAX-L295
              7= HK1-0292-000 1 CABLE, FLAT, 15P
              8= HC1-2021-000 5 KEY TOP, MODE
              9= WG8-5517-000 2 PHOTO-INTERRUPTER, TLP-1243
              10= HM1-0870-000 1 OPCNT BOARD ASS'Y
              11= HC1-2023-000 1 SHEET, LCD
              12= XB4-7301-009 4 SCREW, BINDING HEAD SELF-TPG
              13= HC1-2026-000 3 SHEET
              14= XB4-7300-807 12 SCREW, TAP TIGHT, BINDING HEAD
