Hi fellas,
This month has been crazy about errors.
I have a case with an iPF8000. Error 03130031-2618.
The point is that even in SM it will show the error and not let me do anything.
I cannot even replace print heads.
And the story keeps getting better.
Customer had previously bought a pair of PF-02 print heads.
So I cannot make an upgrade in software because than the plotter would require PF-03 print-heads.
I had a quick look at the plotter (between service visits) and some things are strange.
If you turn on with the "cover open" or "the lever raised" the plotter will sense them, BUT if I close the cover or lower the lever, these actions are not detected by the plotter. I cannot even turn it off at that point, I have to unplug.
Anyone has a clue ?
Anyone has a clue ?
