e 804 error
  • sjinachandran
    • Jul 2025
    e 804 error
    Dear friends
    cannon ir 400 shows E 804 SUB CODE 006, what could be the problum. pl help me.
    regards
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Re: e 804 error
    My book does not list an 804, 803 and 805. 805-0006 is Laser scanner motor cooling fan 2 (FM6)
    • teckat
      • 16083
      Re: e 804 error
      Originally posted by sjinachandran
      Dear friends
      regards
      never see an 804 on a iR400
      look again at that code
      post a pic of control panel that shows that code
      • sx633
        • Sep 2011
        • 49
        Re: e 804 error
        E800 codes are always a fan problem. The favourite on those is the one at the front by the drum.
        • Brian8506
          • 1664
          Re: e 804 error
          sx633 is right. The 0006 is the subcode for the laser fan which is on the front frame by the drum
          • teckat
            • 16083
            Re: e 804 error
            iR400
            that's an 805-0006
            poster said 804-0006
            • Brian8506
              • 1664
              Re: e 804 error
              Opps. You are correct. I went off memory which isn't what it used to be.
              • teckat
                • 16083
                Re: e 804 error
                will the original poster> please stand up
                • sx633
                  • Sep 2011
                  • 49
                  Re: e 804 error
                  E804 doesn't exist according to my manual.
                  E803 is caused when the scan lamp ends blacken and 805 is the laser fan as previously mentioned.
                  i've checked Canon UKs help charts and still nothing there about E804. Are you absolutely sure it is 804 ?
                  • teckat
                    • 16083
                    Re: e 804 error
                    there is no 804 on iR400
                    • sx633
                      • Sep 2011
                      • 49
                      Re: e 804 error
                      E-804 does exist on some Canon models (but not this one according to the manuals) and it relates to a cooling fan on a power supply.
                      Don't always trust the manuals as quite often they are translated through a couple of languages before being published in English.
                      Hope that helps.
                      • teckat
                        • 16083
                        Re: e 804 error
                        maybe it's not a iR400
                        U never know/ they sell third party printers with the wrong door labeled nowadays
