IR 5055 solid black image
  • TEC DOG
    • Sep 2011
    • 113
    I already replace potential sensor unit,laser scanner unit,DC controller PCB,potential sensor cable and connector.Help wanted!Also have E061-0001 time to time,most time first in the morning.
  • charm5496
    • 2387
    Re: IR 5055 solid black image
    Title : E061 Code And Black Copies
    Error :
    Getting E061 error code with Potential Control turned on and black copies with halo around text with Potential Control turned off.
    The Primary Corona Assembly, the Potential Control Assembly, the Laser Unit and the DC Controller PCB were all replaced.
    The Pre-Exposure Lamps come on. The Laser Shutter is completely open. Software was reflashed / updated. DC CON Clear and Main Controller Clear were both performed in service mode.
    VL1M under DPOT in service mode is up to 427. VL1T is at 70.
    With Potential Control turned Off in service mode, changing service mode settings for Primary Corona current and Developing Bias will correct the Copy Quality issue but the service mode settings are way out of spec.
    Workaround :
    The E061 Code and Black Copy Quality issue was resolved by replacing the Image Conversion PCB. Part number for the Image Conversion PCB is FM2-9868-000. Refer to Figure 900 and Figure 950 attached below for locating where the Image Conversion PCB is located inside the imageRUNNER.
    • TEC DOG
      • Sep 2011
      • 113
      For start i reconnect all connectors on Image Conversion PCB and it works.Thanks a lot.
      37GGS1CAKWJ4JCCAE2Y4MXCACKW45PCAAERPMUCA1FUMDPCA64SE8UCAC14MELCA64PCZ0CAE744L1CAV6AOOWCA3H6Q1CCA.jpg
