Canon ir 6000 showing e 005, oil web is ok..checked the sensor , checked the connectors but problom still persists, i checked the fixing unit in other machine its working..fine..what could be the other issues..please help..thanks in advance.
canon ir 6000
Re: canon ir 6000
service mode
highlight FX-WEB, enter 500000 and press "OK".**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: canon ir 6000
Saji,
You may also have to go to function>clear> error. Press ok and turn the machine off on the right
hand side.
This should clear the code. Teckat is correct also in as much the counter has nothing to compare
the current count to. Like a PM counter, under the counter section in service mode you will find
the counter for the web, it wants to compare it a number.
HTH's
DRComment
