ir-2200 hard drive isssue
  • pontiac
    • 420
    We have a ir-2200 that a had a bad hard drive and we replaced it with one from a working unit, but the copier is doing nothing ,screen displays bar then locks up. We have replaced HD's from one copier to another and have not had this issue with ir-2200's before.Any ideas? Thanks....ps this is a regular 2200.
  • bojans
    • 1313
    Re: ir-2200 hard drive isssue
    Did you try to reload software with SST tool?
    • teckat
      • 16083
      Main Controller DIMM could be bad ???
      are both printers networked ??
      they both must have same Boot Rom
      if one is not and the other is / u can't swap HDD between them !!
      u will need to do an overwrite all in SST on working HDD with the correct firmware
