Canon Manuals
  • alcofie
    Canon Manuals
    Hi, can anyone help me with how to configure my Canon IR 3300 to print on the network?
  • teckat
    • 16083
    Re: Canon Manuals
    u first need a
    Network Multi-PDL Print Kit-C1=PCL5e, PCL 6 and PostScript 3 Emulation
    READ------Multi-PDL Printer Kit-C1.pdf
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Re: Canon Manuals
      If your 3300 has an ethernet port on it, you should already have a print kit installed. Additional Functions, System Settings, Network settings. Input the IP and subnet numbers here to get it onto your network. Restart the copier. Go to a PC on that network and type in the IP address you assigned to the copier in the PC's browser address bar and hit enter. You should be in communication with the copier. If it loads the RUI screen, then you should be set copier wise. Install the PCL driver that you can download from Canon onto your PC, configure the PC to add that copier's IP address and you should be good to go...
