Canon IR3570
  • msmy
    • May 2010
    • 123
    [Jamming] Canon IR3570
    Hi.
    I have problem with IR3570 which is paper jammed at drum unit (see pic). Help me please....25092011021.jpg25092011022.jpg
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon IR3570
    Check if you have jam code 107.
    Countermeasure against Jam 0107, which occurs on the second side of sheet in two-sided copy under high-humidity
    environment.
    0107 Jam may occur when a sheet gets into the Drum Cleaner when the second side is being started during the
    two-sided copying under high-humidity environment.
    When the sheet absorbs moisture at two-sided copy, it largely curls against the first side after it is copied. Then,
    at the second side copying, the curling matches the Drum peripheral and that leads to jam because the sheet
    cannot be separated from the Drum.
    ir4570-033.pdf
    • zoraldinho
      • Mar 2008
      • 5007
      Re: Canon IR3570
      By the way don't flash the drum with your camera.
      • msmy
        • May 2010
        • 123
        Re: Canon IR3570
        Dear Zoraldinho,
        Thank you for your advice and tips. . Will try it tomorrow early morning...
        msmy
        • dhanesh
          • Jun 2010
          • 63
          Re: Canon IR3570
          hai friend try to check this machines transfer assembly and check contact point in chase frame to conduct supply to transfer assembly i got this problem some months later in 3570 m/c. am find in that machine broker supply conducting point in frame
          DHANESH
          • teckat
            • 16083
            Re: Canon IR3570
            DRUM looks like crap
            • msmy
              • May 2010
              • 123
              Re: Canon IR3570
              will change with new drum....
              • zoraldinho
                • Mar 2008
                • 5007
                Re: Canon IR3570
                Originally posted by msmy
                Dear Zoraldinho,
                msmy
