Black copy
  • nizam
    • Mar 2011
    • 40
    [Misc] Black copy
    Hello,every body, I have a canon ir 8500, The copy is full black, no image printing, Only photocopy. The print is good.
  • ikon01
    • Apr 2011
    • 53
    Re: Black copy
    don't like to ask a silly question but is your copy lamp coming on?
    • teckat
      • 16083
      Re: Black copy
      CCD Assembly check
      • nizam
        • Mar 2011
        • 40
        Re: Black copy
        ikon 1 & teckat, The scanning lamp goes on. I have Replaced SCANNING LAMP,CCD, laser unit, lamp PCB, D.C controller PCB, lamp cable, M.S.B unit.
        The print out has no problem. Only for copy & mail box
        • teckat
          • 16083
          Re: Black copy
          we already know prints are ok-
          have u actually watched the scanning of the glass copies with the cover up ????
          u need to check the connections for the CCD unit
          check-Mirror Case Flexible Cable
          check-Light Adjustment PCB
          • nizam
            • Mar 2011
            • 40
            Re: Black copy
            Replaced the light Adjustment PCB and i check Mirror
            • Arcking1968
              • Sep 2011
              • 39
              Re: Black copy
              You've try almost everything, are you sure the parts you've test are all good? Did you test it one by one?and regarding black copy there is a totally black copy, and black copy with an image. Try to check if your mirror is reflecting the light at the middle of the lens.
              • nizam
                • Mar 2011
                • 40
                Re: Black copy
                Replaced the light Adjustment PCB[IMG][/IMG] and i check Mirror
                All parts are good. Yes i testing one by one.Totally black copy no image.
                • nizam
                  • Mar 2011
                  • 40
                  Re: Black copy
                  Black copy no image
                  • teckat
                    • 16083
                    Re: Black copy
                    Black copy on image
                    process of elimination
                    if your network prints are good /
                    and your copies from the glass & df have solid black over the image = OPTICS ISSUE
                    you see the text or image from copying under black ??
                    post that picture> adjust the image control to light>make a copy>post the pic here
                    • nizam
                      • Mar 2011
                      • 40
                      Re: Black copy
                      Sir text or image not under the black.
                      • nizam
                        • Mar 2011
                        • 40
                        Re: Black copy
                        Thanks to all. The problem is solved
                        • zoraldinho
                          teacher-guide-expert-guru
                          • Mar 2008
                          • 5007
                          Re: Black copy
                          How????
                          • nizam
                            • Mar 2011
                            • 40
                            Re: Black copy
                            IP board connector to CCD
                            • teckat
                              • 16083
                              Re: Black copy
                              CCD=OPTICS
                              (a trace back) KOOL !!
                              Good Find
                              Troubleshooting an issue is a matter of noted written procedures & process of elimination-
                              it gives u a starting,middle & end point of attack=that prevents in most cases the replacing of unnecessary parts,time wasted & frustrated efforts,
