Hi, for this model irc6800 i heard it can be use as b/w and colour function by 2 separated drum unit. My supplier said theres no individual black toner for sell, we need to get 1 set toner CYMK. Sometimes we mostly print in black and this will make us keep CYM in many if in long term. But i heard somebody said we can use ir5000 genuine toner for irc6800 black and we still not really sure and confident about it even we got pretty lot of ir5000 genuine toner. May be the most experience technician here can verify it? Thank you
irc6800
Re: irc6800
NO>NO>NO>
U have BLACK starter to deal with
imageRUNNER C5800 / C6800 / C5870U / C6870U
GPR-14 Black Toner (8649A003AA) or GPR-26 Black Toner (2447B003AA)
GPR-14 Cyan Toner (8650A003AA) or GPR-26 Cyan Toner (2448B003AA)
GPR-14 Magenta Toner (8651A003AA) or GPR-26 Magenta Toner (2449B003AA)
GPR-14 Yellow Toner (8652A003AA) or GPR-26 Yellow Toner (2450B003AA)
by following the below instructions you can default all copies to output Black.- From the Copy screen select "Auto-Color Select"
- Select "Black"
- Select "Additional Function"
- Select "Copy Settings" and scroll to the second screen
- Select "Standard Settings Button"
- Select "Store" ("Do you wish to store this setting?" will be displayed)
- Select "Yes" to store the setting and "Done" two times to exit the Additional Function screen
Color copies can still be made by manually selecting Auto-Color Select or Full Color.
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: irc6800
O man this is funny. This box of crap is so sensitive and you cant get away with just running black. You need to run color to help uncontaminate the color devs from the black toner that has dropped into them! But by running color you generate simple use that requires way too much work. Hit the red button and call a ditch digger. I did 3.4 million on 6870 with a scumbag dealer who didnt want to buy a new drum. red button then call a ditch digger.Comment
