canon np3020
  • Pault
    [Error Code] canon np3020
    the main ic of my canon np 3020 had an accident and dot broken then i repaired it and the following error code came up f221. the other isure i have with it is that the filament lamp is no longer lighting as should be. Then there is also paper Jam.
    Pleas can some one tell me what to do in other to clear this error code or to reset it.
  • TEC DOG
    • Sep 2011
    • 113
    Re: canon np3020
    If you don't have the same machine to swap parts and make one worked is my advice:
    • Arcking1968
      • Sep 2011
      • 39
      Re: canon np3020
      Most probably if you ask the dealer of the spare parts you need for this machine it is expensive than a new machine.
      Canon NP means "no parts"
