ImageRunner 7200 not printing or scanning
  • mailderrick
    • Mar 2010
    • 131
    I was given the story from a customer (who uses me for most of all their other machines and was told if i get this going she will turn everything over to me):
    They used this machine (until it stopped working a few months back) for printing,scanning, and copying.
    At some point in time it stopped printing and scanning. She said that she can ping to it and she also deleted the drivers and re-set them up and still no printing. I want to try to tackle this but Canon is not my strong point. I am looking to fellow CopyTechNet friends for tips and tricks and any help is greatly appreciated!
    Derrick
  • TEC DOG
    • Sep 2011
    • 113
    Re: ImageRunner 7200 not printing or scanning
    In this case i usually use my notebook and cross cable.
      • 16083
      ; if normal, go step 6).
      If a fault is found in the connection of the network cable, correct the connection, and go to step 5) once again.
      6) Make the following selections in service mode: COPIER>TEST> NETWORK>PING.
      Enter the loop-back address* (127.0.0.1); press the OK key, and then press the Start key. suspect a fault in the TCP/IP setting of the machine. the TCP/IP setting may be assumed to be free of a fault.
      However, suspect a fault in the connection of the network interface board (NIC) or the NIC itself; go to step 7) to make a check.
      * The signal will be returned in front of the NIC, enabling a check on the TCP/IP setting of the machine.
      7) Make the following selections in service mode:, suspect a fault in the connection of the NIC or the NIC itself.
      • mailderrick
        • Mar 2010
        • 131
        Well, I am going to go up there and take a stab at it. She can ping it from the pc so my first thought is maybe the Ip was reissued? Also to enter service mode..is that * then hold @ and 8 at the same time..then *
        I don't quite remember anymore. I will see what i find out when i get there. Thank you!!!
          • 16083
          click on picture
