Hello to all, an ir2230 show me jam code 0205-9. Can any one knows what is the reason for this jam code?
IR2230 JAM CODE O2O5-9
Re: IR2230 JAM CODE O2O5-9
0205 Jam code is defined as a stationary jam at the registration sensor PS9
if no paper is found in flag area>
Probably false code because of stuck flag or bent bracket position
flag may be too close to the sensor > and may not pull all the way back out away from the sensor
indicating stuck paper when no paper is found/ also check the spring position and action of flag
see pic
PS9.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Rudy
