ir 3570
  • Luther
    • May 2006
    • 682
    ir 3570
    I have a problem with a 3570 that keeps calling for toner the bottle rotates and is full, doesnt seem like the dv unit is getting toner,did i dc con clear and it worked for 200 copies. then light came back on, toner is oem,,,any help is appreciated
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Re: ir 3570
    Clean toner sensor on the dev unit it could cotted with toner.Also check toner level in the dev unit,if it is low go to service mode and perform installation of toner in the dev unit,thus:COPIER>FUNCTION>INSTALL.Ensure that the hopper motor is functional.
    • doktor
      • 214
      Re: ir 3570
      • teckat
        • 16083
        Re: ir 3570
        check the Sub Hopper Toner Sensor TS2.
        "Replace Toner Cartridge or Add Toner" is shown on the Display after replacing the Toner Cartridge.
        Check the two Cam Bottle Slides for cracks, replace if needed FC5-1215-000 / FC5-1268-000.NCF000020000_Figure%20621-1.jpg
        • Luther
          • May 2006
          • 682
          Re: ir 3570
          should have mention i cleaned the sensor and did install, no go, didn't work until i did a dc cone clear, shouldn't you get a code if the hopper motor doesn't work?the bottle rotates when it's trying to add toner
          • teckat
            • 16083
            Re: ir 3570
            hope u printed out a P PRINT before the DCON CLEAR/ to put back the settings
            • Luther
              • May 2006
              • 682
              Re: ir 3570
              i did ...thanks
              • Simons
                • Jun 2008
                • 490
                Re: ir 3570
                I had to replace a hopper once for someone and I do believe that this was the cause as there wasnt a toner mess senario observed. Hoppers are only 63 bucks, funny I remember that part.
                • Luther
                  • May 2006
                  • 682
                  Re: ir 3570
                  it was the slides...thanks teckat
                  • teckat
                    • 16083
                    Re: ir 3570
                    Thanks & good luck
                    • zoraldinho
                      teacher-guide-expert-guru
                      • Mar 2008
                      • 4999
                      Re: ir 3570
                      Doktor shot first.
