solution // Problem in high temperature ir 5000
  • bluesky2000
    • 95
    there is no error code or any thing in screen
    look my problem is :
    When printing large quantities of paper
    When the paper out adjacent to each other and the paper will be very hot
    This is the problem I thought that there is a way to reduce the temperature
    solution
    I posted some SERVICE MODE adjustments
    Setting in service mode
    [9] Wait time reduction mode- to reduce print time; for iR5000, 4 min or less; for iR6000, 1 min or less.
    [10] Priority on fixing mode-
    [11] Priority on productivity mode-
    [12] Thick paper mode (120/230-V model only)-
    [13] Special paper mode -
    COPIER>OPTION>BODY>FIX-TEMP
    Use it to select down sequence mode.
    0: OFF, 12: priority on productivity while controlling down
    sequence temperature to
    CHECK
    Heat discharge fan (FM3)
    Exhaust (lower rear)
    this solution with help from
    teckat
  • jiongpao
    • May 2009
    • 413
    Re: solution // Problem in high temperature ir 5000
    Thank for the information ! i got 1 unit of ir5000 oftenly come out with error code of e002 even after change thermistor. Then we got no choice just to off for 30mins and continue to hardcore again after that. This solution will solve my problem by lowering the temp and checking/cleaning the following fan and the air flow section.
