Canon iRC3200 Error Code E000602-0602
  • Gudnex
    • Jun 2025
    My Canon iRC3200 displayed Error Code E000602-0602. What does it mean and what should I do to resolve the problem?
  • prntrfxr
    • 1622
    Re: Canon iRC3200 Error Code E000602-0602
    Welcome. In future, please post your Canon question in the Canon forum on this site for faster response. Thanks.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • HELIO240
      • Jan 2011
      • 137
      hello friend, your problem is the hard disc, it is probably with the system corrupted or bad block. So first you must run the check hd Turning the machine by pressing 1 and 9 at the same time to check the hd. If not the desired result format and install the printer's system with a newer version and it still does not work you should replace the hd. I hope I have helped you.
