Jam in cassette 3 ir5000
  • Sahdy
    • Sep 2011
    • 23
    [Jamming] Jam in cassette 3 ir5000
    I installed a new pickup roller, feeding roller and separation sponge with new ones, sill the feeding through it make jam in repetitive copies.
    What is the real problem? Thanks.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Jam in cassette 3 ir5000
    How many copies have machine?What is jam code?Do you have jam only with one cassette?Are you a tech?
    • Sahdy
      • Sep 2011
      • 23
      It didn't give a jam code. Just jam at the cassatte # 3 only the paper didn't leave it and the copier show jam at touch screen. The machine copied about 2 m till now (the counter show that).
      • zoraldinho
        • Mar 2008
        • 5007
        So you are not a tech i beleve.Call a canon tech.
        • Sahdy
          • Sep 2011
          • 23
          is it for tech only this night, it night now here. I don't want to stay to the morning. Could heip? thanks
          • zoraldinho
            • Mar 2008
            • 5007
            OK.Go to service mode and read the jam code.
            • Sahdy
              • Sep 2011
              • 23
              ok.go to service mode and read the jam code.
              [ATTACH=CONFIG]12150[/ATTACH]
              the jam code is 0105
              So it is a dealy jam / vertical path 3 paper sensor (PS26)
              What does it mean?? wht should I do? thanks again.
              • zoraldinho
                • Mar 2008
                • 5007
                You have delay jam from cassette 3..a4r format,sensor ps26.
                Check pick up unit cassette 3,check sensor 26.
                • teckat
                  • 16083
                  Originally posted by Sahdy
                  01 1005 2334 2335 0 0105 3 108655 a4 r
                  check Cassette 3 --retry sensor PS21
                  01--1005--2334--2335--0--0105--3--108655--a4 r
                  number of jams--date--time--clear time--location--code--paper source--total copy--paper size
                  delay jam>0 is for copier>0105 delay jam>3 is cassette> for 4R Paper
                  is your tray 3 set for a4R Paper ?????????????
                  is this the paper size u have in this tray = a4R ??
                  • Sahdy
                    • Sep 2011
                    • 23
                    [ATTACH=CONFIG]12153[/ATTACH]
                    I cleaned it but it now give jam code 010D
                    cassette 3 re-try sensor (PS21)
                    • Sahdy
                      • Sep 2011
                      • 23
                      The paper size I use when it is in Cassette 1 or 2 it is A4 but when it is (the same paper) in cassette #3 it is A4R
                      also at:
                      copier>dispaly>CST_STS
                      width-C3 A4 R
                      • zoraldinho
                        • Mar 2008
                        • 5007
                        Are you trying to print something or doing SM test print?
                        • Sahdy
                          • Sep 2011
                          • 23
                          No . this happened when I copy and print and it happened most of the time.
                          • Sahdy
                            • Sep 2011
                            • 23
                            and now when i tried to copy 9 repetitive paper from cassette #3 it gave
                            jam code is 0105 again
                            help? what is the problem with it?
                            • teckat
                              • 16083
                              forget about the vertical path sensor-
                              you have a p/u retry >delay from tray 3 to that sensor
                              1- is paper lifting to position ?
                              2- when u pull out tray 3 after jam code is the paper anywhere near from leaving tray ?
                              3-are the feed tires locked in the "up" position ??
                              tell tech to replace these parts below
                              #8-Vertical Path Roller 0 ==FF5-9964-000
                              #9-Vertical Path Roller 1 ==FF5-9965-000
                              #2-Sensing Plate========FF5-9842-000
                              #26-Sensing Plate========FF5-3002-030
                              (Quantity 2)
                              #25-Sensor Mount========FF5-2990-020
                              (Quantity 2)
                              #20-Bushing============FA9-2112-000
                              (Quantity 2)
                              #4-Vertical Path Guide====FB5-2916-030
                              #13-Sensor---PS25=======FH7-7394-000
                              Vertical Path Drive Assembly==FG6-4880-000
                              click on pic for better view
