Question about default setting. Can i set the scan resolution to 200 x 200 black, so that when the reset is hit, it will default to this desired setting?
ir c 5185
Re: ir c 5185
You can set to display a shortcut key to the Black mode next to the color selection drop-down list displayed on the Copy Basic Features screen, Scan screen of the Mail Box function, and the Print Screen.From the Display Panel of the imageRUNNER change the setting from "Auto - Color" to "Black" using the pull down menu.
Press Additional Functions
Select Copy Settings
Scroll down to select Standard Settings
Select Store
Select Yes
Select Done
Now when making copies from the glass, the imageRUNNER will automatically default to Black only.
To store your desired Scanning Mode settings for Send Jobs:
1. On the Send Tab, pull down the Scan Settings drop down menu and select Option.
2. The Scan Settings configuration window will open.
Set the options you want on this screen (ex. Resolution, Document Size, Special Features such as Job Build and Different Size Originals, etc).
* Note - If faxing, be sure to select a supported resolution for faxing (normal - 200x100, fine - 200x200, superfine - 200x400, or ultrafine - 400x400).
3. Click the Store/Erase button.
4. Select a Scanning Mode item on the left by highlighting it. The Scanning Mode items listed on the left are different groups of stored settings.
5. Hit the Register Name or Store Name button to change the name of the Scanning Mode item selected.
6. Press the Store button, verify the settings, and hit Yes to store your settings into that Scanning Mode item. Press Done.
II. To change the default Send settings:
1. Hit Additional Functions.
2. Select Communication Settings (if a fax board is attached, you need to select TX Settings under the Common Settings column).
3. Scroll to and select Edit Standard Send Settings.
4. Set the Scanning Mode (you can select the Scanning Mode item stored previously), File Format (TIFF, PDF, etc), and Divide into Pages options that you want to be the new defaults.
5. Hit OK.
6. The device must be restarted for the new default Send Settings to take effect
Note: This is only for color copiers
1) Select [Additional Functions].
2) Select [Common Settings].
3) Select [Display the Black Mode Shortcut Key].
4) Select [On] or [Off].
5) Press [OK].**Knowledge is time consuming, exhausting and costly for a trained Tech.**
