Fail to install 2 way unit-B1 on Canon IR2520
  • klaws
    • Jul 2025
    [Jamming] Fail to install 2 way unit-B1 on Canon IR2520
    Hello,
    I installed a new Canon ir2520 with 2 way unit-B1 , is no hardware problem but when i try to use 2 side printing or copying the paper jam .The problem is in the software setting, i don't know the right procedure and i don't have a service manual.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5012
    Re: Fail to install 2 way unit-B1 on Canon IR2520
    Problem is bad installation.Software can't be a reason for jaming.What is jam code?
    Do you install all parts?
    1] Wire saddle 2 pcs.
    [2] Reversal trailing end guide 1 pc.
    [3] No.2 delivery unit 1 pc.
    [4] Screw (RS-tight: M3x8) 2 pcs.
    [5] Screw (P-tight: M4x10) 2 pcs.
    [6] Double-sided feed guide unit 1 pc.
    Take the following parts back as they are no longer used:
    [1] Inside right-middle cover 1 pc.
    [2] No.1 delivery fixer guide 1 pc.
    [3] Screw (P-tight: M4x10) 1 pc.
    [4] Screw (RS-tight: M3x8) 1 pc.
    • teckat
      • 16083
      Originally posted by klaws
      Hello,
      jam code please ??
      Jam Log is included in the Error Log. To print out a JAM/ERR Log, perform the following steps:
      Access Service mode> ADDITIONAL FUNCTIONS>2>8>ADDITIONAL FUNCTIONS
      Scroll until you see "# REPORT" hit OK
      Scroll until you see "REPORT OUTPUT" hit OK
      Scroll until you see "ERROR LOG LIST" hit OK
      see pdf----Inner Finisher-B1.pdf
      • klaws
        Thanks for the answer Zoraldinho, i followed the steps from de installation procedure and i think that the hardware is OK, i also installed de power supply unit-U1.I return with the jam report, and also with the software setting that I made.
        When i'm using the 2side option the paper exit first on tray B(printed one side) instead of upper one.
        • klaws
          Originally posted by teckat
          jam code please ??
          see pdf----[ATTACH]12172[/ATTACH]
          i have problem with2 Way Unit-B1 (Enhances the double-sided print productivity), i don't have the Inner Finisher installed.
          I return with the error report.
          • teckat
            • 16083
            turned on in user mode. Use the following steps -
            1) Press "Additional Functions"
            2) Press "System Settings"
            3) Press arrow key to screen 3 of 3
            4) Press "Use Inner 2Way Tray"
            5) Press "On"
            6) Press "OK"
            7) Press "Reset" to return to the main screen
            Restart the printer and the Tray Designation option will be added to the Common Settings screen.
