Trouble using a Canon ImagePress C1 printer
  • dn_gustavo
    • Nov 2009
    • 12
    [Misc] Trouble using a Canon ImagePress C1 printer
    Hello everydody,
    A have a Imagepress C1 Printer and on the last days it become to make me a crazy.
    Some prints are doing with a colored risks, and the machine is not maintening the same color into the copies.
    My english is so bad, so I have scanned the images and post on the link below.
    I have changed all developers and toners.
    http://www.copycolor.com.br/clientes...stavo/C1_1.jpg
    http://www.copycolor.com.br/clientes...stavo/C1_2.jpg
    http://www.copycolor.com.br/clientes...stavo/C1_3.jpg
    Thanks a lot if anyone can help me.
  • jacky_kuo
    • Aug 2011
    • 54
    Re: Trouble using a Canon ImagePress C1 printer
    I have the same failure problems, please replace the Dc controller pcb or Llaser unit , then you can troubleshooting ...
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5017
      Are you a tech?
      It's look like drum issue.To be shore post a pg-10 test from service mode.
      • zoraldinho
        • Mar 2008
        • 5017
        You can't start with 1000$ parts.There is service manual procedure!
        • jacky_kuo
          • Aug 2011
          • 54
          Originally posted by zoraldinho
          Are you a tech?
          Yes , I am .
          But I do'nt think so this is the drum issue....
          Our on-site customer have the same problems above occur images iPRC1+ x 3,
          1 was replaced DC controller PCB, 2 was replaced the Laser unit....
          This three customers per month about 15000 SRA3,
          After replaced that parts , there had 0.5 to 1 year did not occur this problem....
          Therefore, I can be 100% sure......
          • teckat
            • 16083
            Originally posted by dn_gustavo
            Hello everydody,
            how and where are those images from ??
            scanned in on glass to print ?
            scanned to PC than printed ?
            or created from an application to be printed ??
            POST PG5 PRINTS- SINGLE COLOR
            POST PG10 PRINT
            POST A PG 6 GRID PATTERN-
            that one print with corona streaks-
            Check that the Primary Suction Fan Filter is present.
            Accumulated dust will contaminate the Primary Charging Assembly.
            • DANIELCANON
              • Jun 2011
              • 187
              • teckat
                • 16083
                I had that problem which was solved by the laser unit. out a few lines of different colors sometimes not all.
                good point
                • zoraldinho
                  • Mar 2008
                  • 5017
                  Do you replace Laser assembly only or Laser scanner assembly?
                  • DANIELCANON
                    • Jun 2011
                    • 187
                    Fm2-6066-000 laser scanner assembly
                    • Ricardo25
                      • Feb 2013
                      • 9
                      Hola,
                      Bueno a mi tambien me tiene loco esta falla ya cambie DC controler PCB y laser espero funcione porque intente de todo, gracias por la aportacion.
