Background intermittent 105
  • davidj7
    • 1107
    Hi
    I am getting intermittent background on my iR105 . If i open and close any of the doors or casette the background goes for another 5000 A4 prints .
    I have changed the DC controller ,MFC, IP board , Laser Unit ,Power Supply , DP unit(mag roller unit ),carona primary and transfer.
    Please advise on what to do next .
    thanks
    a machine is only as good as your tech : source:screwtape ; the scary one
  • vigour
    • Aug 2010
    • 1038
    Re: Background intermittent 105
    how many copies on the drum?
    i think you need to polish your drum with canon drum cleaner, or something similar.
    also try running with potential sontrol off, see if there is a difference.
    • teckat
      • 16083
      AP Kit ??
      Check the wiring harness in the front of the AP kit for continuity. A poor connection through the harness may cause the Pre-Exposure lamps to turn on intermittently.
      AP Kit Cable FG6-7204-000.
      Developer bias ???
      • vigour
        • Aug 2010
        • 1038
        you are right.
        it does sound more like precon lamps.
        • davidj7
          • 1107
          I have changed the whole drum unit .
          teckat :I donno if the part number you gave is on the drum unit . I will replace the precon lamp with that of a working machine and check
          thanks
          • teckat
            • 16083
            thanks
            FG6-7204-020 > HARNESS CABLE is in AP KIT
            • gensys
              • Jan 2011
              • 323
              Hi
              thanks
              The problem in optical system seems to me. And mirrors & CCD checked ????
              The Road will be Mastered by >>> the Going...
