iRADC5051/ C5045/ C5035/ C5030---Troubleshooting Various E075 causes
  • teckat
    • 16083
    [Error Code] iRADC5051/ C5045/ C5035/ C5030---Troubleshooting Various E075 causes
    imageRUNNER ADVANCE C5051/ C5045/ C5035/ C5030
    ***Before replacing the ITB Assembly, Canon USA strongly recommends following this
    Publication to identify the root cause of the issue at hand.
    see pdf>>>TP10.pdf
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: iRADC5051/ C5045/ C5035/ C5030---Troubleshooting Various E075 causes
    • gensys
      • Jan 2011
      • 323
      see pdf>>>[ATTACH]12197[/ATTACH]
      The Road will be Mastered by >>> the Going...
      • Paul 75
        • Oct 2008
        • 97
        So with the info given , its a safe to say that if I have a 50 series on a cassette ped, i will have to do this adjustment as standard ?
        Oh...... I can't copy at the moment then ? !!!!!!
        • teckat
          • 16083
          it's your choice to follow or leave it up to the next tech
          • Paul 75
            • Oct 2008
            • 97
            I've started getting issues with 35/45's where the belt displaces to the front so I get the75 error. These machines have only done 75 - 150 k so the ITB must be good. All have cass peds on all of the machines. Has the adjustment to the feet of the peds been a success ? . Canon Europe seem to be months behind Canon US....
            • teckat
              • 16083
              Just released in USA/ only time will tell
              • vigour
                • Aug 2010
                • 1038
                It works. CHECK the other areas first.
                Pedestal adjustment was the first solution released,
                then they were providing replacement assemblies.
                They have obviously found all these other issues on the returned assemblies
                • KL568
                  _
                  • Feb 2011
                  • 324
                  Yes, can re-affirm this information has helps a lot in resolving E075. We carry leveling-gauge to measure the machines' 4 corner whether it on stable ground. Now I basically use the Service Mode value to ensure it reach as close to value of 0 as possbile for "ITB-POS"
                  i had 1 unit reaching half million runs without any E075.
                    Canon USA tech info in general seems to be a lot better as well.
                    Back on topic
                    The transfer belt assembly is not available as a complete unit in the UK as far as I know because its considered a "controlled part"
                    • vigour
                      • Aug 2010
                      • 1038
                      it us controlled
                      and it was controlled
                      • alaa1005
                        Old Member
                        • Jul 2011
                        • 8
                        Thank you for useful data
