printing from pc to irc 4080
  • nkclr
    • Oct 2011
    • 6
    [Misc] printing from pc to irc 4080
    I want to print a banner 300mm X 600mm to irc4080. From windows i have the option to register this size of paper, but when i load the paper on stack tray there is limit of 320 x 457
    • 16083
    Re: printing from pc to irc 4080
    Stack Bypass-Irregular Size
    - Paper Size: 3 15/16" x 5 7/8" to 12 5/8" x 18" (99 mm x 140 mm to 320 mm x 457 mm)
    That is it-for this model
    If you select [Irregular Size] for copying, you cannot use the Poster, Finishing, Book 2-Sided, 2-Page Separation, Cover/Sheet Insertion, Image Combination, Booklet, Transparency Interleaving, Job Block Combination, or Store In User Inbox mode.
    • nkclr
      • Oct 2011
      • 6
      I don't want to use poster option. I want to use long paper.
      On help i found this:
      For the iR C2380/2550, C2880/C3380, C3080/3480/3580, C3080/C2880-J1, C3580/C3380-J1,
      C4080/C4580, C4080/C4580-H1, C5180, C5180-H1, C5185, and C5185-H1,
      custom paper sizes with height settings greater than 457.2 mm (18 inches) are treated as Long Paper
      • nkclr
        • Oct 2011
        • 6
        See also this:
          • 16083
          See also this:
          [ATTACH=CONFIG]12258[/ATTACH]
          You will need to press Additional Functions, Custom Common Settings, and select the stack bypass size entry option. This option must be turned on. It will now prompt you to select the paper size installed in the stack bypass.
          NOTE: When finished, verify the setting by hitting Paper Select in copy mode. The stack bypass should show the correct paper size that is installed.
          2. In the print driver properties (Start>Settings>Printers>Right-click Properties). Go to the Device Configuration Tab and hit the Form to Tray Assignment button.
          Set the stack bypass to the correct paper size (loaded in the stack bypass).
          3. Make sure the document to be printed is formatted to the correct paper size within the application it is being printed from.
          For example, if you are trying to print to Letter paper in the stack bypass, then the document should be formatted to Letter size. Choose File, then selecting Page Setup within the application itself.
          4. Finally, must select the correct paper size within the print driver and must select the stack bypass as the Paper Source.
          Now the document can be printed (pulling correctly from the stack bypass).
          set up your STACK BYPASS SETTINGS
          12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement-R,
          Executive, 12-5/8" x 17-11/16",
          Irregular size (3-15/16" x 5-7/8" to 12-7/8" x 18") and Envelopes
          Select STACK BYPASS
          Press [Irreg. Size].
          -Enter the size of the paper using the numeric keys on the touch panel display.
          -Press [X] - enter a value.
          -Press [Y] - enter a value.
          -Press [OK].
          (The X value defines the short edge, and the Y value defines the long edge).
          To select a registered paper size stored in a size key ([S1] to [S5]), you must store
          the irregular paper size in the size key beforehand.
            • 16083
            See also this:
            imageRUNNER 3045 / 3035 / 3030 / 3025 / 5075 / 5065 / 5055 / 3245 / 3235 / 3230 / 3225, imageRUNNER C2550 / C3080 / C3480 / C2280 / C3380 / C4080 / C4580 / C5180, All imagePRESS Series
            Paper Type Management Settings (Name the Paper)
            This feature allows users to specify, edit, and manage select media types within the imageRUNNER device. In the previous imageRUNNER devices, users could select from several standard paper types when registering their media. With some of the newer imageRUNNER models , users can now specify a name based on the specific properties of the media (I.e. Letterhead). This will allow for easier identification, and help reduce the risk of inadvertently selecting the wrong paper type when specifying for copy or print jobs.
            -Custom paper type names can be specified at the control panel or through the Remote User Interface.
            -Users can specify up to 200 custom paper types with new names in addition to the default paper types already registered in the device
            -Users can only edit the contents for NAME. Detailed information for CATEGORY, BASIS Weight, FINISH, and TYPE are displayed.
            -Once a new name has been stored, it will appear in the 'Detailed Settings' section when specifying a paper type within [Additional Functions], [Common Settings], [Register Paper Type].
            -If a custom name has been registered for one of the paper sources, the registered paper name is viewed on the control panel screen when the drawer is selected in the 'Paper Select' function.
            52.jpgYou can also access this option using Remote User Interface, Select Additional Functions, Custom Settings, Paper Type Management Settings.
            • nkclr
              • Oct 2011
              • 6
              I know how to setup the paper size.
              My problem is this:
              In this chart referred that supports custom paper size 320x630(long size paper) but there is a limit up to 457mm when i try to register an Irreg. Size paper.
                • 16083
                My problem is this:
                [ATTACH=CONFIG]12316[/ATTACH]
                never seen that page before/ not official
                CANON TYPE ERROR
                this is the largest size paper for bypass-
                12-7/8" x 18" is the largest irreg.size u can set it to
                on this model
                • vigour
                  • Aug 2010
                  • 1038
                  It does not matter what the salesman or the book says.
                  If the machine is giving you a limit , that is it until you or canon re-programs it.
                    • 16083
                    This may work> for paper up to 630 mm long
                    Have your answer```````````SERVICE MODE
                    - Press [Additional Functions (*)] key.
                    - Press 2 and 8 of the numeric keys at the same time.
                    - Press [Additional Functions (*)] key. => SERVICE MODE LEVEL1
                    >U then go into LEVEL 2 of service mode to set the Long Length mode
                    (After starting up [SERVICE MODE] , press [Additional Function] button again. Then, by pressing [#2] button on control panel, the LEVEL 2 screen is displayed.
                    MF-LG-ST Sets long length mode key on control panel for bypass tray,SELECT "1"
                    Setting values
                    0: Normal setting
                    1: Display long length key in mode screen.
                    [Factory settings and after RAM clear: 0]
                    hit OK! To set>then exit mode
                    Long Strip Original option will only be visible in the Special Features tab of the Copy screen
                    • nkclr
                      • Oct 2011
                      • 6
                      THAT' s IT !!!!
                      Thank you very much my friend. I was ready to buy a color printer to print long papers.
                      you are the BEST !!! ;-)
                      • V-P
                        • Apr 2011
                        • 679
                        looki looki !
                        I didn't know that !
                        Teckat - you are one of a kind !
                          • 16083
