IR-5000 SPOTS AGAIN
  • T911
    • Jun 2007
    • 628
    IR-5000 SPOTS AGAIN
    Replaced drum 2 months ago worked for about 45k but its back. See attached. Thanks t
  • teckat
    • 16083
    Re: IR-5000 SPOTS AGAIN
    Replace the Developer Unit.
    Check for arcing from the primary or developer unit to the drum surface.
    • adhy
      • Feb 2011
      • 109
      Hi try to replace Roller Spacer(FB2-8519-000) on developing unit.
      • BillAgudelo
        • Feb 2010
        • 84
        The Mag-roller is worn out. Replace it.
        I've seen this before.
        • Hopper
          • Jul 2008
          • 173
          I have seen how the mag roller wear out on the rear. 2nd guess is I have seen that pattern when the primary wasn't in right and tight.
          • ernesto
            • Oct 2011
            • 430
            yes, I have seen it once and the photocopier was working again after replacing 2 roller spacer.
