iR3200 Tech Tip on Old Fuse Pcb & E602-0001
In heat related conditions, the 5V input to the hard disk may become unstable causing the hard disk to detect a low voltage condition resulting in intermittent E602-0001 error codes.
if you experience E602-0001 and need to replace the HDD>
also check the lot number of the DC Fuse PCB
If the last two digits of the lot number are or , -New DC Fuse PCB Assembly FG3-2337-030 or Later
