CANON IR 2270
  • aoseikwame
    • Mar 2011
    • 25
    CANON IR 2270
    I have this error code e000020 0000 on my screen, pls any help.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: CANON IR 2270
    The path between the sub hopper and the developing assembly is clogged with toner.
    The developing assembly toner sensor
    detects the absence of toner, while the
    sub hopper toner sensor detects the
    presence of toner. With the developing
    clutch turned on, the hopper feedscrew
    motor is rotated for 1 sec intermittently
    194 times; still, the developing assembly
    toner sensor does not detect the presence
    of toner.
    FK2-0358
    Replace the developing assembly toner
    sensor. Replace the sub hopper toner sensor.
    Replace the DC control PCB.
    Need to move inner finisher if you have one to get sub-hooper sensor.Second one is on developer.Sensors are the same.
    Good luck.
    • teckat
      • 16083
      Re: CANON IR 2270
      sensors output can be checked at the DC Controller PCB
      Inspect the toner motor drive and the auger mechanism for any foreign object damage
      • TEC DOG
        • Sep 2011
        • 113
        Re: CANON IR 2270
        How you can check sensors for developer and sub hooper from service mode please?
        • teckat
          • 16083
          Re: CANON IR 2270
          COPIER>I/O screen<DC-CON>
          BITS are left to right=High to Low (0)
          EXAMPLE BELOW
          P001 xxxxxxxxxxxxxxxx
          High(15)------------>Low (0)
          Bits 15>8 are not used for DC-CON om this model
          Address-Bit-Display contents-Action
          P020-1 -Bottle rotation motor/ 1:ON
          P020-2 -Hopper screw motor/ 1:ON
          P021-1 -Toner detection/ 1:Toner remaining
          P023-4 -Waste toner sensor/ 0:Full
          P030-3 -Hopper level sensor/ 0:No toner
          E020-0000 // Recovery Sequence
          The machine is not equipped with a mechanism to detect the replacement of its toner cartridge, but is designed to execute toner recovery sequence in response to the following, assuming that the cartridge has been replaced:
          1. the front cover has been opened and closed after the machine has detected the absence of toner inside the toner cartridge and the developing assembly.
          2. the machine has been turned off and then on after it has detected the absence of toner inside the toner cartridge and the developing assembly.
          The machine's recovery sequence is as follows:
          1. the machine rotates the toner cartridge motor. (intermittently by rotating it for 3 sec and stopping it for 2 sec)
          2. if the toner level sensor inside the sub hopper detects the "presence of toner," the machine stops the recovery sequence.
          3. after repeating the foregoing intermittent operation 20 times and if the toner level sensor inside the sub hopper still does not detect the "presence of toner," the machine will assumes that the toner cartridge has not been replaced and cause the toner cartridge motor to stop.
          • TEC DOG
            • Sep 2011
            • 113
            Re: CANON IR 2270
            Thanks a lot!
            • mramlawi
              • Jul 2011
              • 838
              Re: CANON IR 2270
              some times gear of the the cylinder broken it happen once with me .
              Distinguished road makes you jewel in rough
