IR-2220
  • T911
    • Jun 2007
    • 628
    IR-2220
    what the heck is the reference point for the auto detect for the guides in the bypass tray on this one. i was fooling with it for about an hour and couldn't get it in the right spot. i did notice the arrow on the belt but couldn't get it. i don't have the sm for this one. thanks much t
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: IR-2220
    Im not shore to undestand your question.Maybe this pdf can help!
    pick up.pdf
    • teckat
      • 16083
      Re: IR-2220
      what are u trying to detect - paper size>paper> or transparencies
      • T911
        • Jun 2007
        • 628
        Re: IR-2220
        Paper size
        • teckat
          • 16083
          Re: IR-2220
          Paper size
          FOLLOW THE POSTED MF Tray adjustment above
          Use it to make cassette/manual feeder-related adjustments.
          If you have cleared the RAM on the DC controller PCB and replaced the PCB, be sure to
          enter the settings indicated on the service label. If you have replaced the paper width detecting
          VR or want to enter settings newly, be sure to execute FUNCTION>CST in service
          mode.
          Using the Mode
          1) Place A4R paper in the multifeeder, and adjust the side guide to A4R.
          2) Select <MF-A4R> to highlight, and press the OK key.if u don't have listed paper look at guide marks to set
          COPIER>ADJUST>CST-ADJ>MF-A4R
          Use it to adjust the paper width basic value of A4R paper for the manual
          feed tray.
          COPIER>ADJUST>CSRT-ADJ>MF-A6R
          Use it to adjust the paper width basic value of A6R for the manual feed tray.
          Use it to adjust the paper width basic value of A4 paper for the manual feed
          tray.
          • sivagurunathan
            Re: IR-2220
            please check the wiring and change the manual feeder size detection switch
            • T911
              • Jun 2007
              • 628
              Re: IR-2220
              It was the manual tray pcb and switch. Teckat thanks for your post too.
              • teckat
                • 16083
                Re: IR-2220
                thanks,
                u will usually be pointed to the correct area by many of the forum contributors
