e00611-0000
  • kiwiyorky
    • Aug 2025
    [Error Code] e00611-0000
    Have got aCanon iR3045 with an error code e00611-0000 which is not in the service manual. It seems to point to the image proccessor or Sram. Has any one got any ideas please as nobody seems to have had this fault.
    Many thanks
    Kiwiyorky
  • BillAgudelo
    • Feb 2010
    • 84
    Re: e00611-0000
    E00611-------------> Rebooting repeat error due to SRAM failure, etc.
    Reseat or replace RAM.
    • ics
      Re: e00611-0000
      And how do I reset the RAM?
      • teckat
        • 16083
        Re: e00611-0000
        Many thanks
        Kiwiyorky
        E611 Error in repeat of reboot due to fault of the SRAM, etc.
        -0000 = SRAM information has failed, job information stored in the SRAM cannot be read and a reboot is repeated at recovery from powering off .
        are u a tech ????????? if not place a service call
        did this happen after a Fax Transmission
        Try and disconnect the Fax PCB connection inside printer & then re-start printer/
        for information purpose only
        in service mode-------------------------------
        COPIER > FUNCTION > SYSTEM>CHK-TYPE
        Specifying a partition number for executing HD-CHK
        <Operating procedure>
        1) Select item.(select #1) only
        2) Select a partition number with the ten-key pad.
        0: Entire HDD
        1: Image accumulation area
        2: General-purpose file (user-defined data/various log data/PDL spool
        data/image data management information) storage area
        3: PDL-related file storage area
        4: Firmware/address book/file storage area
        5: MEAP area
        6: Address book area
        Remarks: HD-CLEAR shall be indispensable for 4 and 6.
        HD-CHECK
        Checking and restoring the partition specified by CHK-TYPE
        1) Select this item.
        2) Press the OK key.
        3) The result (1:OK, 2:NG (hardware), 3:NG (software) restored/
        alternative sector) is displayed.
        HD-CLEAR
        Initializing the partition specified by CHK-TYPE
        or---------------------------------------------------------------
        U could try a MN-CON CLEAR
        Service Mode > COPIER > Function > CLEAR > MN-CON.
        WARNING: BEFORE U TRY THIS--
        Make sure to back up all data (Mailboxes, Network settings, ID #s, passwords, address books, service mode settings, etc.) before executing Main Controller Clear in service mode.
