Canon Counting Pages
  • alban123
    • Jun 2025
    Hello everybody. I have a Canon MF6540PL and i want to keep track of the printed and copied pages(printed jobs), but there is no option in the printer menu(kind of reporting list option). I have tried with different software but still no results. Thank you in advance..
    • 16083
    Re: Canon Counting Pages
    LaserBase MF6530 / / LaserBase MF6540PL / LaserBase MF6550 / KaserBase MF6560PL / / LaserBase MF6580PL
    This copier is furnished with a maintenance/supplies counter set (DRBL-1), which can be used to gain rough measures of when to replace supplies.
    The counter set increments by one on counting each sheet of small-sized paper (up to A4/LTR) and by two on counting each sheet of large-sized paper (larger than A4/LTR).
    TOTAL (Total counter)
    SERVICE1 --Service total counter 1
    SERVICE2 --Service total counter 2
    TTL --Total counter
    COPY --Total copy counter
    PDL-PRT --PDL print counter
    FAX-PRT --Fax print counter
    REP-PRT --Report print counter
    2-SIDE --Double-sided copy/print counter
    SCAN Scan counter
    PICK-UP (Paper pickup counter)
    C1 --Cassette 1 jam counter
    C2 --Cassette 2 jam counter
    C3 --Cassette 3 jam counter
    C4 --Cassette 4 jam counter
    MF --Manual feed tray pickup total counter
    2-SIDE --Double-sided paper pickup total counter
    FEEDER (Feeder related counters)
    FEED --Feeder pickup total counter
    DFOP-CNT --ADF open/close hinge counter
    JAM (Jam counters)
    TTL--Unit total jam count
    FEEDER --Feeder total jam count
    SORTER --Finisher total jam count
    2-SIDE --Duplex unit jam counter
    MF --Manual feed tray jam counter
    MISC --(Other required counter) WST-TNR Waste toner counter
    Parts counter list
    Item----Counter----Explanation----Service life
    DRBL-1 (Unit supplies)
    FX-UNIT--Fixing unit paper pass count---150,000
    TR-ROLL--Transfer charger roller high-voltage ON count---150,000
    DV-UNT-C--Developing unit rotation count---150,000
    M-PU-RL--Manual feed tray pickup roller paper pass count---150,000
    M-SP-PD--Manual feed tray separation pad paper pass count---150,000
    Clearing Counters
    - Maintenance/parts counter all clear
    Execute service mode > CLEAR > COUNTER to clear all maintenance/parts counters.
    - Counter clear on parts replacement
    Press the numeric keypad key 0 after displaying the counter for a part just replaced, and the counter will be cleared individually.
    Report Output (REPORT)
    COUNTER REPORT=Counter output
    Maintenance/supplies counter output.
    (For more detailed information about the maintenance/supplies counter output,
    execute service mode > Display counter information > Counters.)
    RUI ???
    Remote User Interface
    • alban123
      Sorry but i cant understand (im not that much into printers). Is it kind of supply, is it a software or an option in the printer system which i havent discovered yet? Thanks
      • V-P
        • Apr 2011
        • 679
        If your machine is connected in a network, than by typing the ip address of the printer in explorer, you can see all the counters you need to see.
        Comprende ?
          • 16083
          READ>>>>RUI.pdf
          System Requirements for the RUI:
          1.Operating System - Windows 9x PC, Windows NT 4.0 + SP 3 or higher, Windows 2000, Windows XP, Windows Vista, and Windows 2003.
          2.Web Browser - Internet Explorer 4.01 SP1 or higher, Netscape Navigator 4.6 or higher
          How to configure the RUI:
          1.Set the RUI to On, under Additional Functions, System Settings, Remote UI. (make sure that HTTP is also enable and no IP address ranges are set for HTTP access)
          2.Type in IP address of the imageRUNNER in the browser address bar.
          • alban123
            Comprende ?
            What about the copies? I want to count the copies too.
            • alban123
              thanks a lot guys. ill give a try tomorrow and see if it works.
              • alban123
                Originally posted by teckat
                READ>>>>[ATTACH]12433[/ATTACH]
                [ATTACH=CONFIG]12432[/ATTACH]
                Are you sure this works for my model (mf6450pl). I cant find the network card installed in the printer so i cant connect it to the network. I have connected it into a pc and shared in all the network. Furthermore, i couldn't find the Remote UI under the System Settings. Please help me it is urgent.
                  • 16083
                  sorry, think the MF6580 in your series, only has that RUI turn on feature in system settings
                  Remote UI (MF6595cx/MF6595/MF6590/MF6540 Only)
                  Before you start the Remote UI, select <VIEW IP ADDRESS> in <NETWORK SETTINGS> located in the <SYSTEM SETTINGS>, and verify the IP address of the machine.
                  then>>>>>>>>>
                  Start the web browser, enter the IP address of the machine, then press [Enter] on the keyboard
                  • alban123
                    then>>>>>>>>>
                    The problem is that my printer doesnt have the network card or network connection, so it could not have the ip. Is there any program or any printer option ?
                      • 16083
                      Canon imageWARE
                      About imageCLASS MF6540
                      http://www.canon-europe.com/For_Home...NSYS_MF6540PL/
                      Duplex Copier - Laser Printer - Color Scanner - Network Capabilities
                      Network connectivity using AXIS 1650 Print Server
                      • Up to 24 pages-per-minute laser output
                      • Duplex versatility - automatic two-sided copying, printing, and color scanning
                      • 500-sheet cassette plus, 100-sheet multipurpose tray
                      • Legal-size platen
                      • 50-sheet Automatic Document Feeder letter-size paper
                      • Built-in Ethernet port for network printing
                      • Scan in color up to 9600 dpi quality with 600 dpi optical resolution
                      • USB 2.0 Hi-Speed for optimal performance
                      • Single Cartridge System
                      • Canon Generation Green
                      • Energy Star Qualified
