I am getting a "replace cartridge" error on a Canon Laser Class 710 machine. Different cartridges tried and still no luck. It lets you print 1 page then displays the message and the next print that comes out is blank. Anyone have any ideas on what causes this? Thanks!
Canon Laser Class 710 "replace cartridge" Error
Re: Canon Laser Class 710 "replace cartridge" Error
check that it has 3 tabs for bias along the side
check the Drum Ground contact on the Rear Plate Assembly
check the metal contacts on the toner cartridge position to the contacts on the EPU board
EPU board could be toast
best to call for trained tech to investigate this board/pain to replace>it's a massive disassemble**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
avengence
are u using refilled units/re-manufactured ones ?????
Is the EPU board the one that the laser unit connects to, or the board on the right side?
What is the rear plate assembly?Comment
[ATTACH=CONFIG]12426[/ATTACH]Attached Files**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
