iR1023iF USB Scangear
  • northernlife
    • Sep 2011
    • 847
    Hi Folks,
    From my understanding a 1023iF scanning via USB requires the iR toolbox and the iR Scangear driver. I can find the toolbox app but not the ir scangear. Anyone got a link for this. Networking is not an option unfortunately.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: iR1023iF USB Scangear
    Scangear is only network option.Use this link...iR1024i
    • charm5496
      • 2387
      Originally posted by northernlife
      Hi Folks,
      if you want to scan via USB then you have to use the toolbox software.
      • teckat
        • 16083
        Hi Folks,
        Network ScanGear is not supported with the imageRUNNER 1023 / 1023N / 1023iF models.
        Color pull scanning is available on these models via the USB 2.0 interface using ScanGear iR and iR Toolbox.
        Push scanning
        via Color Universal Send is available on the imageRUNNER 1023iF
        (not on the imageRUNNER 1023 / 1023N).
        ScanGear iR - ScanGear iR is a 32-bit TWAIN and WIA (Windows Image Acquisition) compliant driver that is bundled with the main unit. WIA is a standard for downloading images from scanners or digital cameras (on Windows XP only). Through the imageRUNNER 1023 Series color scan feature, users can capture and digitize important information for easy storage/archival or incorporate it into other documents electronically from the platen glass or DADF.
        iR Toolbox - In addition to its advanced scan driver, the imageRUNNER 1023 Series includes Canon iR Toolbox, an intuitive, easy-to-use tool bar that sits on the desktop and takes the complication out of scanning. Along with the ability to specify a multitude of scan settings, iR Toolbox lets you choose from a variety of additional options such as:
        [Mail]: The document will be scanned and attached to an e-mail message in your email application.
        [OCR]: The text will be scanned and read by the OCR software.
        [PDF]: The text will be scanned and saved as a PDF file.
        [Scan-1], [Scan-2]: The text will be scanned and appear in the registered application (up to 8 characters long).
        Below is the iR Toolbox that is available on your desktop:
        Scanning through the iR Toolbox is accomplished as follows:
        1) Place originals on the platen glass or in the document feeder.
        2) On the Windows desktop, double click the [Canon iR Toolbox 4.9] icon to open the iR Toolbox.
        3) Click one of the scanning buttons.
        4) Specify the required settings (iR Toolbox Settings).
        5) Click [Start].
        6) Specify the required settings (ScanGear iR Settings).
        7) Click [Scan].
        Creating One PDF File from Two or More Pages: This feature has the ability to scan two or more pages and make them into one PDF File. Plus, the ability to choose from PDF Settings such as:
        [Create Searchable PDF]: Converts the characters in the document to text data and makes the PDF document searchable with keywords.
        [Text Language]: Select the language of the text to be scanned.
        [PDF Compression]: Select [High] for color images such as photos or illustrations to be further compressed.
        Scanning Large Documents: This feature provides the ability to scan a document larger than the platen glass by combining pieces scanned separately using the 'Stitch Assist' mode.
        Scanning with the Windows Image Acquisition (WIA) Driver (Windows XP only): In addition to being TWAIN compliant, the new imageRUNNER 1023 Series devices offer WIA-compliant Scanning as standard for downloading images from scanners used with Windows XP.
        Variety of file formats: User's may choose from a variety of file formats to use when scanning documents including popular PDF formats. You may even create searchable PDF files to search documents by using keywords. The chart below displays the different file formats in conjunction with the different Toolbox options:
        • northernlife
          • Sep 2011
          • 847
          This is fixed, Canon Canada didn't have the iR Scangear on their site. They replied with the package. Wasn't asking for network scangear either btw but thanks :-)
          • teckat
            • 16083
            Check Mark.jpggood find
            • northernlife
              • Sep 2011
              • 847
              Just an FYI that the iR scangear package is quite the pickle to find. not on CUSA's site and not on CC's site either. If anyone needs it just PM me and I'll slap it on a filesharing site.
              • teckat
                • 16083
                imageRUNNER 1023
                Canon U.S.A. : Support & Drivers : imageRUNNER 1023
                Network ScanGear v2.21
                Color Network ScanGear v2.71
                • northernlife
                  • Sep 2011
                  • 847
                  the iR Scangear isn't there. the iR Scangear is for USB scanning only and is different than the network scangear driver.
                  Originally posted by teckat
                  imageRUNNER 1023
                  • teckat
                    • 16083
                    COLOR HAND.jpgKOOL~:
                    CANON USA LINK has iR_TOOLBOX v4.9
                    • KL568
                      _
                      • Feb 2011
                      • 324
                      [ATTACH=CONFIG]13125[/ATTACH]KOOL~:
                      Just to clarified this iR Toolbox, it only software that dont contain the driver for scanning via USB cable. Had attend few Customer with iR Toolbox installed but cant use scanner. After install the driver for USB cable scanning, all problem solved and get to charge Customer cos Helpdesk unable or cant understand it.
                      • KL568
                        _
                        • Feb 2011
                        • 324
                        Actually, to avoid this situation, always advise Customer to keep the original CD with the machine. It will contain the drivers of PCL5 / PCL6 / UFRII / Fax and the USB driver. So after running the CD, all these will be installed in that PC, that is the only annoying thing about it.
                        • HELIO240
                          • Jan 2011
                          • 137
                          Hi Folks,
                          so using this copier software canon scan toolbox to go, it is necessary to install the driver on the PC first, preferably for installation from a CD with the original driver, here we had several problems trying to install the IR toolbox downloaded from canon, if prefer the in between it has 4 shared a link with my original cd just download.
                          • KL568
                            _
                            • Feb 2011
                            • 324
                            It seems that without original CD, you are still able to get the scanner driver from CUSA web sites. Problem being it was not clear in the download link's comments (refer attached) that is causing Customers' headache on where to get scanner drivers. The worst thing is that this download link was posted since 2007.
                            • HELIO240
                              • Jan 2011
                              • 137
                              It is a canon of this, sometimes that puts a few things not working. Tired of having problems with this and the original cd without having their hands because the User loses every cd. I copied the cd and put this link (4shared folder - My 4shared) is so if you want to download.
