Ir3035 duplex jam
  • maddy4u
    • Feb 2010
    • 19
    Ir3035 duplex jam
    please help me, why ir 3035 always jam at Duplex mode. Jam code is 010A
  • ernesto
    • Oct 2011
    • 430
    Re: Ir3035 duplex jam
    Once I have a problem with Irc 2380i always jam in the duplex mode, the sheet was one half outside machine and the other half inside 2nd 3 rd delivery assembly, I checked the connectors and cleanned the sensors and the machine worked ok again until now.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Check paper quality.Do you have jam from all cassetes?could be guide sticking.
      • maddy4u
        • Feb 2010
        • 19
        Yes Paper Jammed from All Tray & Jammed between 2nd 3 rd delivery assembly.
        • teckat
          • 16083
          010A Jam only While Duplexing.
          This jam can be caused by the tab on the second delivery flapper being damaged or broken, preventing the flapper from operating correctly. The part number for the flapper is FC5-1003-040.
          also--Check the One-Way (FU5-3018-000)on the back of the A1 unit. ( located on the Right Door)
          • maddy4u
            • Feb 2010
            • 19
            Flapper & One Way is Ok
            • teckat
              • 16083
              how do u know the one-way is functioning properly ??
              test turn by hand=not a true test
              looks are deceiving
              • nogood boyo
                • Mar 2012
                • 156
                i have a similar issue with a 3035 that was crazy dirty... took me a good four hours to clean up.
                changed out the cleaning roller and fixing web.
                before it was cleaned paper was jamming at the fixing unit, now it is only occasionally jamming at the fixing unit during a duplex... other than that it prints fine.
                i also replaced all of the paper that was being used.
                any suggestions for a duplex jam at the fixing unit? thanks.
                • tones27
                  • Jun 2012
                  • 18
                  also you can check inside the inner two way unit and see if the flag came out of place
