canon ir3035
  • Walter
    • Aug 2025
    canon ir3035
    I am getting dirty copies only on duplex
    need to know how to clean duplexer area
    and duplex feed path
    any help will be greatly appreciated
    thanks Walt
  • charm5496
    • 2387
    Re: canon ir3035
    pull it apart and clean with the chemicals that you have????
    What kind of "dirty copies" are you getting on the back side? Usually this is a drum/developer or fuser issue. Dirty guides normally give you dirty edges.
    • Walter
      Re: canon ir3035
      the dirty copies only on duplex side
      gets better when you make many blank copies
      I'm thinking the fuser unit when it comes for the second pass
      thanks
      • charm5496
        • 2387
        Re: canon ir3035
        yes I would pull out the entire unit as toner likes to build up on it anyway. Take a good look at your cleaning roller and your film.
        • Simons
          • Jun 2008
          • 490
          Re: canon ir3035
          Clean every thing you can see. There will be toner debris on the paper for awhile after cleaning up a messy machine. Is the drum leaking towards the back? Sometimes if they let the drum leak or use it when its really streaking waste toner can get into the transfer roller area and can cause some dumping on the papers . Can also block a sensor under the charge roller. You can see four posts that hold the transfer asembly to the door. Take that apart to clean. You could take the door off first and get better feel and look at the duplex path.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Re: canon ir3035
            Toner may leak from the sub hopper unit or developing assembly to inside the machine
            The shutter of the hopper assembly is adapted to open when the edge of the developing assembly pushes the shutter
            lever at the rear side of the machine in response to forward movement of the developing assembly. Because of this
            mechanism, in the case that the shutter lever is not pushed enough when the developing assembly is inserted into the
            machine, a clearance that permits toner to escape is created between the hopper and the shutter.
            New FC5-1253-000 SEAL, ENTRANCE
            New FC8-1089-000 SEAL, HOPPER AUXILIARY
            When the machine is running, the toner may leak from the area around the toner delivery mouth between the sub
            hopper [1](P-1) and the developing assembly.
            To prevent toner leak at the hopper assembly, the foam rubber sheet [2](P-1) is attached to the sub hopper [1].
            If you have soils at the leading edge:
            1.If the above symptom occurs, replace the upper transfer guide [2] with the new type of upper transfer
            guide(FL2-0304-030).
            • Walter
              Re: canon ir3035
              Thank you all Very much
              • Onetouch
                • May 2008
                • 62
                Re: canon ir3035 Blank print and copies!!!
                I have Canon IR3035 and I'm getting blank print and copies. When I change the drum it prints for a day or so and then it starts to give me blank paper again. Has anyone ever had such as problem?
                • CanonSco
                  Man About Town
                  • Jul 2010
                  • 368
                  Re: canon ir3035
                  thanks
                  Pay special attention to the fuser inlet guide. In a "dirty" machine as described above by the other guys , the inlet guide is a prime culprit. Take it off and remove the hard toner as well as giving it a clean.
                  Only other addition to what has been said already is to change / clean your door filters.
                  Yes, I am a nerd.
                  Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
