Transfer Mailbox to PC W7
  • andalasgt
    • Oct 2010
    • 49
    [Misc] Transfer Mailbox to PC W7
    Is it possible to transfer Mailbox of iR6570 to PC W7? How...
    Thank you
  • teckat
    • 16083
    Re: Transfer Mailbox to PC W7
    imageRUNNER 2270 / 2870 / 3570 / 4570 / 5070 / 5570 / 6570 / 8070 / 9070 / 105+ / 7086 / 7095 / 7105 / 3025 / 3030 / 3035 / 3045 / 5050 / 5055 / 5065 / 5075 / 3225 / 3230 / 3235 / 3245, imageRUNNER C2880 / C2880i / C3380 / C3380i / C4080 / C4080i / C4580 / C4580i / C5180 / C5180i / C5185 / C5185i, All imagePRESS Series
    With the newer devices-You can back up the mailboxes to a shared folder on a computer and then later restore them on the machine. This option backs up the mailbox name, password, and also the contents of the mailbox. Perform the following steps to set up this option:
    1. From Remote User Interface, select Additional Functions.
    2. Select Custom Settings.
    3. Select Backup/Restore Settings.
    4. Select Backup Destination Settings and enter the settings as follows:
    HOST IP ADDRESS: \\COMPUTER_NAME_OR_IP_ADDRESS\shared_folder_name.
    FILE PATH: path to the folder within the share (blank if sending to root of shared folder).
    USER NAME: enter a valid user name that has write privileges to the host that you are sending to.
    PASSWORD: enter the valid password for the user that you have entered above.
    5. After setting up the destination settings then you can use the backup option to backup the mailboxes to your computer and then the restore option to restore it on the machine
    backup.jpgNOTE: It is possible to schedule mailbox backup jobs and to perform differential backups on certain models.
    • andalasgt
      • Oct 2010
      • 49
      Thank you very much Sir for your quickly respond, I will try it later and will report the result.
      • andalasgt
        • Oct 2010
        • 49
        Finally, Mailboxes backup done .... Thank you Sir .....
        • teckat
          • 16083
