service manual
  • sergio carmona
    • Oct 2011
    • 11
    [Misc] service manual
    Hello, iam sergio, from mexico and i need the service manual canon imagepress C1,
    Thanks for help
  • JustManuals
    • Jan 2006
    • 9838
    Re: service manual
    And what do you have to offer in return?
    • sergio carmona
      • Oct 2011
      • 11
      Re: service manual
      I have manual, canon irc 3200/3220
      ricoh 2075
      xerox dc250
      xerox dc12
      etc
      • JustManuals
        • Jan 2006
        • 9838
        Re: service manual
        Nah, I have all of those.
        • cesar.m
          • May 2011
          • 12
          Re: service manual
          hi sergio do you have any system software of a fiery i need the system image pass s1 and s2, i have the manual of c1 we can change it
          saludos!!!!!
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Re: service manual
            Hi Sergio.Tell us what's wrong with the printer.Maybe is your lucky day.
            • sergio carmona
              • Oct 2011
              • 11
              Re: service manual
              saludos!!!!!
              Sorry, i don have system sofware.
              • sergio carmona
                • Oct 2011
                • 11
                Re: service manual
                code E000009-0001
                • charm5496
                  • 2387
                  Re: service manual
                  This error indicates a bad main or sub power supply. After checking the power supplies, it was discovered that this code can also be generated by a loose connection to the buffer decurling unit. These are the connectors that go to the copier from the decurling unit.
                  This is the connector for your decurler and can easily be come partially disconnected causing your error
                  • charm5496
                    • 2387
                    Re: service manual - more information for error
                    The machine would not come to a "Ready" state. It would show an E009 with sub code 0000. All 24 and 13 Volt lines were good from the power supply to the DC Controller. We did not have 24 volt at J1164, pin 10 going to the De-Curler pcb from the DC Controller.
                    • alexctx
                      • Dec 2010
                      • 157
                      Re: service manual
                      de mexico , si tu c1 es de 110v, si no has cambiado el enchefe que tiene cable mas delgado mas delgado. fijate que este bien enchufado.eso es porque no le llega voltaje al desrisador o bufer.
                      cambia el enchufe o tu tomacorriente.si no invierte el los enchuches don de los conectas y te daras cuenta.
                      • sergio carmona
                        • Oct 2011
                        • 11
                        Re: service manual
                        Thanks, I served a lot of your help, the team is already working
                        • sergio carmona
                          • Oct 2011
                          • 11
                          Re: service manual
                          Si gracias, por la ayuda, si efectivamente tenia un falso contacto en uno de los pines de 24 volts. pero ya quedo gracias
                          • sergio carmona
                            • Oct 2011
                            • 11
                            Re: service manual
                            Hola. una pregunta soy nuevo en esta maquina y ya repare lo del codigo de la discucion, pero enfrento un detalle y no se como se cambia la configuracion: El problema es el siguiente cuando la uso como copiadora scac el papel bien directo a la bandeja, pero cuando la quiero usar de printer manda la impresion hacia abajo como si fuera duplex y no se la puedo cambiar, me podrias ayudar?
                            Gracias
                            • alexctx
                              • Dec 2010
                              • 157
                              Re: service manual
                              Gracias
                              manda la impresion como si fuera papel personalisado ejemplo si es un a4 dile que 211mmx298mm.
                              si fuera un un a3 dile que 421x298 ha esto solo funciona si lo mandas del baypass porque este permite pasar papel personalizado.
