help E824-001
  • tongee
    • Nov 2009
    • 50
    [Error Code] help E824-001
    Help me is that the ir 6570 E824 - 001, I changed the fan plymary and DC, but it also depends.
    I want to check for substances where there is no lack. I let the team know it. thank
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5014
    Re: help E824-001
    Replace fun connecting cable
    Servicing work:
    To prevent the aforementioned symptom, add the Fan Connecting Cable that is newly set up as a service part by the following procedure:
    1) Open the front Cover.
    2) Open the Toner Cover.
    3) Remove the 2 screws and detach the Toner Supply Cover.
    4) Remove the screw and detach the Connector Cover.
    5) Connect the Fan Connecting Cable [2] to the Front Cable [1], (P-2).
    Note: Be sure to place the whole Cable into the space so as to prevent it from being trapped by the Connector Cover
    [3], (P-3).
    6) Follow the reverse order to attach all the parts removed.
    New CABLE, FAN CONNECTING --- FM3-0074-000
    • tongee
      • Nov 2009
      • 50
      Re: help E824-001
      [ATTACH=CONFIG]12578[/ATTACH]
      Servicing work:
      [3], (P-3).
      • tongee
        • Nov 2009
        • 50
        Re: help E824-001
        Thank you
        • zoraldinho
          • Mar 2008
          • 5014
          Re: help E824-001
          Originally posted by tongee
          Thank you
          You are welcome.
