iRC 3200 toner
  • Apach
    • 157
    [Misc] iRC 3200 toner
    Hello,
    I need quick help if posibile. Atm I must wait 2 days for new toner but I need tonight to print. Im put black toner from C-EXV17 in catrige from irc3200 before replace toner msg, but after short time device says replace black toner
    I dont have new toner or reset chip on disposal. Is there a way to get around it? Far as I know there is an option in service mode by which this can be done.
    There is no stupid question, just stupid answer
  • charm5496
    • 2387
    Re: iRC 3200 toner
    Originally posted by Apach
    Hello,
    drill a hole in each of them and pour the toner from the cartridge you cant use into the cartridge that is for the machine. Make sure the hole is on the top!!! and then seal it back up with a plug. It should get you through till your new toner arrives. Just be careful and go slow when pouring as it will make a mess and I would get a funnel of some sort as well to help out with the process.
    I do not recommend this process, but when you are in a pinch this should work.
    • Apach
      • 157
      Re: iRC 3200 toner
      Problem is in chip. 3200 have a RF chip .... 4080 have a contact chip....toner from 3200 can go in 4080.. Problem in chip. On irc4080 you can put tape on one contact and you receive error msg but possibilie to print. 3200 have RF chip and after cca 20-25k copies dont let you to print although the charge cartridge. This is problem. Toner in C-EXV17 and C-EXV8 are almost identical and for first help is good
      • charm5496
        • 2387
        Re: iRC 3200 toner
        that is why I suggested to drill a hole and transfer the toner into the container that works in your machine!!!!!
        • fchu5959
          Field Engineer
          • Jun 2010
          • 100
          Re: iRC 3200 toner
          [QUOTE=Apach;254614]Hello,
          I dont have new toner or reset chip on disposal. Is there a way to get around it? Far as I know there is an option in service mode by which this can be done.[/QUOTE
          Hi,
          if you need to black print only, you can swap the toner black chip with that of a color cartridge;I think the machine will allow you to make black prints only!
          cheers]
          • Apach
            • 157
            Re: iRC 3200 toner
            Problem solved. I drove today 200km and bough toner. Also I have ordered 10 pieces toner reset chips for future
            Still, if someone know how to overide in service menu please reply here or through PM. Thanks in advance
            • mailderrick
              • Mar 2010
              • 131
              Re: iRC 3200 toner
              I think i am kind of lost! How would transfering toner into a cartridge with a dead chip help?
