IRC2380i : Message: "The default key is not set".
  • Rachid.Akli
    • Oct 2011
    • 595
    I have this message on different canon models. Please, I would like to know why is it displayed, The consequences on the machine and the way to clear it.
    Thanks in advance.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
  • nivssluck
    • May 2008
    • 228
    Re: IRC2380i : Message: "The default key is not set".
    Thanks in advance.
    there is a thread for this. you can search and browse it here...
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      After performing MN-CON clear:
      If you clear MN-CON in the Service Mode (Service Mode > COPIER > FUNCTION > CLEAR > MNCON),
      the Key will be corrupted and some cases the CA Certificate cannot be used.
      In this case, you can also solve the problem by setting the Service Mode (Service Mode Level 2 >
      COPIER > Function > CLEAR > CAKEY. Turn the main power OFF and ON).
      • HELIO240
        • Jan 2011
        • 137
        Thanks in advance.
        service mode level 2 clear> ca-key
        after additional function > system settings > look for generate new key. and register. after turn off and turn on the copier.
        • zoraldinho
          • Mar 2008
          • 5015
          5 months old thread
