Need help >>>> have a problem with the second side
  • gensys
    • Jan 2011
    • 324
    [Misc] Need help >>>> have a problem with the second side
    Greetings guys
    iR 6570 the first side both at copying and at printing during the double-side press prints ideally precisely and the second side is printed with offset on direction Y approximately on 5 mm.
    By the client demands ideally exact double-side a copy, the machine new, transversed 340000. By means of service mode > adjust > ADJ-XY it turns out
    For example....
    There is MS Word Dogument >>> page setup: top 20mm, bottom 20mm, left 20 mm, right 20mm
    iR copying secon side >> top 25 mm, bottom 15mm, left 20mm, right 20mm
    Whether probably the machine to adjust ideally precisely?
    In advance I thank for All answers
    The Road will be Mastered by >>> the Going...
  • vigour
    • Aug 2010
    • 1038
    Re: Need help >>>> have a problem with the second side
    copier > adj >feed adj> adj refe
    • teckat
      • 16083
      ADJ-REFE
      Duplexing Feeder Unit>
      1) Select the following service mode COPIER >
      ADJUST > FEED-ADJ > ADJ-REFE, and make an
      adjustment so that margin on the 2nd side image
      will be within specs.
      Use it to adjust the horizontal registration for duplex mode. adjustment range: -50 to 50
      Decrease the value of ADJ-REFE <------
      (Margin is decreased by 1mm with decrease of 10)
      Increase the value of ADJ-REFE ------->
      (Margin is increased by 1mm with increase of 10)
      • gensys
        • Jan 2011
        • 324
        Re: Need help &gt;&gt;&gt;&gt; have a problem with the second side
        Everything is all right, installed -30 instead of -14
        Especially I thank
        vigor & teckat for first aid
        I wish All the successful working day and a lot of many money..............
        • teckat
          • 16083
          mikejack.gifThanks
