how remove the sorter of ir3570
  • AIT MAMEUR
    • Jun 2008
    • 59
    Hello, i'd like to know if i can remove the sorter of ir3570. thank you
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: how remove the sorter of ir3570
    What kind of finisher do you talking about?
    • AIT MAMEUR
      • Jun 2008
      • 59
      the finisher is inside of the ir3570
      i have removed the finisher but there are message about the finisher.
      • doktor
        • 214
        Sometimes people use search!http://www.copytechnet.com/forums/ca...tray-part.html
        • costd
          • Jan 2008
          • 409
          At times it would help if you include the error message you are getting.
          Just taking a wild stab at it - I suspect you are missing the trays and flags that are removed when installing an S1 finisher. I suggest you find a copy of the installation manual/sheet for an S1 finisher and just do it in reverse - after getting the parts the instruction sheet says are no longer used.
          • teckat
            • 16083
            Macgyver.jpg GOOD LUCK on getting these parts needed
            Finisher S1 Install.pdf
            these are the parts below that u remove & throw away when u attach a S1 FINISHER
            click on pic for better view
            think this is what u need>
            #7-Delivery Tray/FC5-1114-000
            #6-Inner Rear Cover Lower/FC5-1106-000
            #5-Inner Panel Rear Cover/FC5-0942-000
            #4-Support Cover/FC5-1117-000
            #3-Lower Cover Left/FC5-1108-000
            #2-Lower Cover Right/FC5-1109-000
            #1-Flag Full Detect/FC5-0798-000
