Firmware for Canon irc5800
  • Vincent2000
    • May 2025
    [Error Code] Firmware for Canon irc5800
    I am looking for the firmware or system software for Canon irc5800. I need this as I am trying to upgrade the machine with fax function. I bought a second hand 3G fax board , fitted in the machine and get the machine turned on it returned error code E000674-0001. i turn the machine off and disconnected the wiring between the machine and the fax board . The machine powered well. I did try Canon but it seemed they did not want to give it to me though they did not actually said so and I think they would ask for $$$$$$..... I looked at the service manual and realized I needed SST v1.8 + and the system software loaded in the SST to do the upgrade. I have managed to find SST v 4.11 and 2.01 on the net but so far my search for the firmware seems to be fruitless. Would someone kindly help with the files ? This would be much appreciated.
  • teckat
    • 16083
    Re: Firmware for Canon irc5800
    After installing fax board, E674 0001 is displayed.
    u do not have a firmware issue
    Power cable to the fax board is not plugged in.
    The cable is a 4-pin connector and it sits behind the power switch.
    techs fail to install it
    *This is not in the set up instructions.
    for Super G3 Fax Board-U1/ or Super G3 Fax Board-P1 make sure this is the board u installed
    EXAMPLE ONLY FOR POWER CONNECTOR THAT MAY NOT BE PLUGGED IN FROM PRINTER TO FAX BD.
    • Vincent2000
      Thank you Teckat. I found the cable and plug it in the Fax board. Now all is running and working perfectly. You must be a very experienced Tech. Your advice is highly appreciated and Thanks again.
      • teckat
        • 16083
        The Dude.jpgThanks & Good Luck
        • gensys
          • Jan 2011
          • 324
          It is real money
          The Road will be Mastered by >>> the Going...
