ir6000i "mail box"
  • br21
    • Jan 2008
    • 22
    ir6000i "mail box"
    hi!
    i really need help!
    i bought used ir6000i and after powering up i've got "mail box" screen...
    like this:
    i would like to have normal copying screen...
    when i want to change initial function i have no choice:
    what to do?!
    thanx for help!
    regards
    bartek
  • Copier_Guy
    • 543
    I know this is going to sound vague, but there is a way to do this. I don't have a machine in front of me, but I can guide you in the right direction.
    First select all the initial settings you want to show up when machine is powered up. (Copy Screen, 1 copy selected...etc.)
    Then you have to go into " * Additional Functions " and select "Common Settings". Scroll down until you see "Initial Settings".
    I believe there is a selection there to "Save Settings". Hit save and the machine will save what you setup as the initial screen. I hope this takes you in the right direction and helps to solve your problem.
    Let us know how you made out.
    • br21
      • Jan 2008
      • 22
      thanx for your reply!
      the main problem is i don't know where to set those initial settings (copy screen), as it is shown in second picture of my previous post i have no choice there - i've got only "mail box" button there
      • Copier_Guy
        • 543
        Is what you're telling me is that you can't select copy functions at all? While you're in the mailBox screen, you can't close that screen and select copy or scanner?
        • br21
          • Jan 2008
          • 22
          exactly!
          • 11x17
            • Apr 2007
            • 153
            quite possibly it is not recognizing the reader. I dont know if you can get it without a reader. If it definitely has a reader than make sure all cables and connections are tight. Let us know
            • Copier_Guy
              • 543
              If what 11X17 doesn't do it, you'll need to call a service person to either Clear the NVRAM on certain areas of the machine or reload the system software.
