Convert IR8500-C To IR8500 N System Software
  • mindhunter
    • May 2008
    • 142
    hi everybody.
    I have system software of Canon Ir8500 And Ir8500-N . but I have Some Copiers That they Are Ir8500C series.
    I wanna know How Can I Change These Copiers To Ir8500 N ?
    Is it possible .
    If it is Im waiting For Your Helpfull Suggestion.
    Thanks.
    With Best Regards .
    Mindhunter
  • teckat
    • 16084
    Re: Convert IR8500-C To IR8500 N System Software
    Originally posted by mindhunter
    hi everybody.
    Is it possible .
    Thanks.
    With Best Regards .
    Mindhunter
    Need a Network Printer Kit
    - take your pick
    Printer Kit B1 - imageRUNNER 8500 only (discontinued)
    Printer Kit B2 - imageRUNNER 8500/105
    Printer Kit B3 - imageRUNNER 7200/8500/105
    Printer Kit B4 - imageRUNNER 7200/8500/85/105
    6935-A012-AA
    Printer Kit B5 - imageRUNNER 7200/8500/85/105
    • nivssluck
      • May 2008
      • 228
      hi everybody.
      Is it possible .
      Thanks.
      With Best Regards .
      Mindhunter
      Since you have a N system software, all you have to do is to flash the bootrom to N or (@ teckat stated) then load the system software N using SST. (I have bundle of this one)
      • charm5496
        • 2387
        you cannot go from a 'C' to an 'N' without a chip copier/burner which is illegal. You need to purchase an 'N' bootrom and then reload your system in order to connect for printing.
        • nivssluck
          • May 2008
          • 228
          Hehehe...I am not using chip copier/burner for this machines. I am using canon machine instead and through SST. (is it illegal?)
          • charm5496
            • 2387
            so you can create an 'N' bootrm with a 'C' bootrom using the SST....BULLSH!T
            • nivssluck
              • May 2008
              • 228
              you do not know that is why you call it BULLSHIT...(ask me how and i will tell you)
              • charm5496
                • 2387
                please enlighten all of us then.
                • teckat
                  • 16084
                  • nivssluck
                    • May 2008
                    • 228
                    sent you a private message
                    • charm5496
                      • 2387
                      Originally posted by teckat
                      [ATTACH=CONFIG]12645[/ATTACH]
                      [ATTACH=CONFIG]12646[/ATTACH]
                      ROFL....I am in tears!!!!
                      • teckat
                        • 16084
                        Software Mismatch Error
                        technician is trying to flash a machine with a N version of system software
                        and there is a C version Boot ROM installed on the main controller board.
                        Using SST
                        You cannot flash a C Boot ROM chip to a N Boot ROM chip, or vice verse.
                        You must physically replace the Boot ROM chip.
                        When registering firmware for the iRC3220 there is
                        no distinction between N or C version in the Service Support Tool. When you flash the C3220 simply select 'BOOT'
                        imageRUNNER 3025 / 3030 / 3035 / 3045 / 5050 / 5055 / 5065 / 5075 / 3225 / 3230 / 3235 / 3245, Color imageRUNNER C2550 / C2880 / C3080 / C3380 / C3480 / C4080 / C4580 / C5180 / C5185, imagePRESS C1 / C1+ / C7000
                        On these devices you no longer need to install an "N" Boot ROM to enable printing. These devices will always have a 'C' Boot ROM listed.
                        Print kits are enabled through an LMS license key and, once registered, will enable the device to print.
                        You can confirm which PDL's are supported on your device by pressing the 'Counter Check' button on the control panel. Once in the counter check screen, select the 'Device Confirguration' button on the LCD. Scroll down to the installed options and you will see which PDL's the device supports. You will see either UFRII, PCL and/or PS if those print kits have been registered.
                        NOTE: If you have an external RIP, such as an imagePASS J1/H1, colorPASS GX-100 or imagePRESS T1/Q1, you will not have any PDLs listed on the copier because there are no internal print kits installed on the device. In this case printing is controlled by the external RIP and you will still use the 'C' Boot ROM.
                        • nivssluck
                          • May 2008
                          • 228
                          [QUOTE=teckat;255245]
                          Using SST
                          Case Closed.JPG[/QUOTE
                          hahahaha!!! if you work from canon before you should know this...(disappointed)
                          • nivssluck
                            • May 2008
                            • 228
                            by the way, the title of the topic is ir8500 not ir3220 or whatoever
                            • teckat
                              • 16084
                              EXPLAIN YOUR HIDDEN PROCEDURE THERE ARE NO SECRETS HERE
